Go to Post it's called the Mars Rock automode (you sit there and wait for Opportunity to come along). - EricH [more]
Unread 25-01-2006, 15:40
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
Re: Gyro Code Problems
Originally Posted by railerobotics
I did exactly what was in Kevin's instructions.
Sorry for being very new to programming
Try downloading just the gyro code form Kevin and see if it works.
Look at the user_routines.c in the PURE gyro code.
Unread 26-01-2006, 09:30
naor52 naor52 is offline
FRC #1578
naor52 is an unknown quantity at this point
i did that and i didn't get reasonable values
because i move the sensor 90 degrees and back where he was and i don't get the same values which i get i n the start
Unread 26-01-2006, 22:37
6600gt's Avatar
AKA: Lohit
I havent tried yet but I think the sensor gives you the change not the actual value.
Unread 27-01-2006, 10:45
ldeffenb ldeffenb is offline
AKA: Lynn Deffenbaugh (Mr)
None #0386 (Team Voltage 386)
ldeffenb has a spectacular aura aboutldeffenb has a spectacular aura aboutldeffenb has a spectacular aura about
Send a message via ICQ to ldeffenb Send a message via AIM to ldeffenb Send a message via Yahoo to ldeffenb
Remember that the gyro has a maximum turn rate that it can report. Turning faster than that (which is easy to do when holding the gyro in your hand) will cause signal overflows which translate into lower rotations report than actually occurred.
Try doing your test and turning the gyro VVVVEEEEERRRRRYYYYY SSSSSSLLLLLLLOOOOOOWWWWWWLLLLLLYYYYY and see what happens.
$0.02 from Lynn (D) - Team Voltage 386 Software
Trying to import Camera code into program without. Kingofl337 Programming 1 18-02-2005 00:43
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
Coding / Style Standards for sharing C code Joe Johnson Programming 33 01-05-2004 15:15
Wierd gyro code problems...pls help Salik Syed Programming 4 14-03-2004 01:29
