Go to Post FIRST is the only sort of competition that I've seen where somebody can win and the opponents can be genuinely happy for them. - RiceRobotica [more]
Unread 25-01-2006, 19:28
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: The Chester Challenge 2006
Originally Posted by KenWittlief
if you do that math on this part of it, lets say you fire at 12M/s and you fire all 10 in 5 seconds.
that means each ball is flying at 1/2 S intervals, which will put them 6 meters apart
thats a lot of space between the balls in flight: 10" balls with 226" of empty space between them
the odds of two balls hitting in flight is 10/226 = about 5 out of 100.
The odds are 20:1 in your favor (no collisions in midair)
I would be most worried about the goal being able to keep up. Assume that it takes a two seconds to stop a ball and clear it, out of the box, into the chute. Say also, for simplicity sake, that three balls are capable of doing this at the same time. So say you have, best case scenario, 30 balls in ten seconds.
So, you have ten, 3 balls instances of clearing. At two seconds apart. So, to clear all the balls, it would be 10*2 =20 seconds to clear all the balls completely. So, by the end of the ten seconds, there would be ten seconds of balls to clear, backed up. (10/2)*3 balls~15 balls left
So at the end of the period (through my rough estimation), there are fifteen balls to clear, or, towards the end of the autonomous period, there are 10 or 12 to get in the way.
I wonder if 10 or 12 balls, some still jangling around, could present enough of an obstacle to prevent some incoming balls from coming in? And what about the feeder chute? I wonder if that'll jam? I think, on top of needing a killer alliance to do it, this challenge is going to be harder than the intro suggests...
-Sir Francis Bacon
-Albert Einstein
Unread 12-03-2006, 21:50
Wayne C.'s Avatar Unsung FIRST Hero
Wayne C. Wayne C. is offline
hey- I think we did pretty good?
FRC #0025 (Raider Robotix)
Wayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond repute
two weeks over- and the TIKI is still safe at home
Thirty balls scored in autonomous? Three robots each getting all three balls in the center goal? A 100 point autonomous round...
Could the challenge AGAIN be beyond the abilities of the ENTIRE FIRST community?
True- the new alliance picking rules seem to inhibit alliances of three hot shooters.
But how many bots are scoring 10 balls in autonomous anyway?
I predict that IF this challenge can be met it wont happen until the elimination rounds at the Nationals.
Until then the TIKI continues to gather dust.....
WC
you want that robot to do what?
Raider Robotix- www.raiderrobotix.org
Unread 12-03-2006, 22:21
tbush503's Avatar
tbush503 tbush503 is offline
The Tree
AKA: Travis Bush
FRC #0173 (RAGE)
tbush503 will become famous soon enough
I don't think this challenge is as practical as you think it is.
Some teams don't even have the capability of shooting, and most that do are not that accurate or are going purly on dead reconing as to where the goal is. The chance of getting 3 teams on an alliance that can even shoot in 10 balls in autonomous are slim.
Those robots that use the camera to target take a while to find the light, especially if the camera is hooked up to a slow moving turret. The time it would take to Drive close to the target, track it, and fire ten balls off is far greater than 10 seconds.
The opposing team normally has at least one robot that is programed to simply drive forwards, the idea being that the robot would interfere with an opposing robot and prevent them from scoring. This would throw off almost all dead-reconing shooters and most tracking shooters (at least it would prevent one ball from going in).
This challenge is no small task. It would take, in my opinion, a miracle to accomplish. The chances of it being done are far below 0%.
Unread 13-03-2006, 16:27
FRC #0306 (CRT)
After having attended one regional, my previous views on this challenge have changed drastically. Seeing the lack of shooters(including ourselves), and the low autonomous capability of even the better shooters, I think this challenge is nearly impossible. Simply the fact that balls bounce out lower the chances to nearly zero, let alone getting an alliance with that kind of firepower. My thoughts: the Tiki with accumulate another years worth of dust. Perhaps the challenge would be nearly possible if changed to "twenty balls in the center goal during autonomous" or "All thirty balls scored during autonomous, anywhere".
-Sir Francis Bacon
-Albert Einstein
Unread 13-03-2006, 16:36
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
This leaves us dumpers out of the question
Unread 29-10-2006, 20:29
So- did anybody do it?
The closest we came was in one round of IRI (that was rerun!) where the three partners got in 27/30 balls.
Anybody get all 30?
WC
Unread 29-10-2006, 22:12
FRC #0306 (CRT)
I didn't hear anything about it. I think the Tiki should just be raffled next year...
-Sir Francis Bacon
-Albert Einstein
Unread 29-10-2006, 22:35
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Anybody get all 30?
Wayne, I thought we nailed 28? Regardless, it's not 30. Can we get a piece of it? What about some of that dust that's coating it?
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 29-10-2006, 22:56
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Umm, technically that match was restarted. Too bad.
Unread 29-10-2006, 23:09
I remember the Newton division winners came pretty close.
Oh wait, there was a dumper bot on that alliance..
Unread 29-10-2006, 23:15
BBnum3's Avatar
BBnum3 BBnum3 is offline
Ridiculously proud of MN First
AKA: Nat Thompson
FRC #1816 (The Green Machine)
BBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to behold
Send a message via AIM to BBnum3
At Wisconsin during eliminations 111 and 1625 each made all of theirs, but I think that match probably had to be restarted. But hey that's still 100% accuracy, that's got to count for something doesn't it ?
Founding member of Team 1816.
2006 Pennsylvania Robot Challenge (PARC) team222badbrad Off-Season Events 91 17-05-2006 15:45
DARPA Grand Challenge 2006 mechanicalbrain Chit-Chat 4 12-01-2006 23:00
pic: A New Challenge in 2006 Noah Melamed Extra Discussion 2 12-01-2006 12:29
[Official 2006 Game Design] OK, so YOU design the 2006 game... dlavery FRC Game Design 29 08-01-2006 00:21
