Go to Post Real coaches dont use "strategy assistants" during matches. - Rick [more]
Unread 24-01-2006, 21:32
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Running K. Watson's code on Edubot, BRLOD
Since it seems our '06 controller isn't working (long story) I'm trying to work on the camera with our Edubot controller.
I downloaded Kevin Watson's camera code (streamlined version) and opened it up in MPLab. I followed the directions in "Using_Last_Years_FRC.txt" (Change device/libraries/etc.) I then compiled and uploaded the file to my controller.
I have the camera connected correctly. Pan is pwm01, tilt is pwm02, power is on pwm03 and serial is connected via rs232->ttl adapter on the TTL port.
However, when I turn the controller on I get a blinking red light of death (BRLOD) on "Program State"
I threw in a couple printf's to see if I could diagnose the point of failure. I put printf's in at
  • Line 178 (after the #endif of #ifdef TERMINAL_SERIAL_PORT_2)
  • Line 180 (after Putdata(&txdata); and before User_Proc_Is_Ready())
  • Before Tracking_Info_Terminal();
  • After Tracking_Info_Terminal();
  • After Camera_Handler();
  • After Servo_Track();
None of these print out, so it seems that something may be failing in or before the serial port initialization.
Does anyone have any idea of what's wrong, because I sure don't
http://www.mikesorrenti.com/
Unread 24-01-2006, 21:50
CmptrGk's Avatar
CmptrGk CmptrGk is offline
Programming Mentor
AKA: Dillon
FRC #0716 (Who'sCTEKS)
CmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud of
Re: Running K. Watson's code on Edubot, BRLOD
try putting the flies into the edubot's default code if you have not already. also did you read the thing about including stdio.h when using printf with the edubot controller.
"Great autonomous mode Dillon."," It hasn't been written yet"
after an Archimedes match
Unread 24-01-2006, 22:16
Mike's Avatar
AKA: Mike Sorrenti
I just tried importing all the seperate components into one Edubot project and it still doesn't work.
Also, stdio.h is included on all files that use printf.
Unread 25-01-2006, 01:26
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Try this code: http://kevin.org/frc/edu_camera.zip. As I haven't tested it, please let me know whether or not it worked for you (I'd be suprised if it didn't work).
-Kevin
Kevin Watson
http://kevin.org
Unread 25-01-2006, 13:37
heydowns's Avatar
heydowns heydowns is offline
AKA: Jeff Downs
FRC #1511 (Rolling Thunder)
heydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond repute
-Kevin
Mike - if Kevin's .zip gives you trouble, PM me and I will send you our camera-enabled code which runs on EduBot. That is how we are doing our initial work, too.
I basically took the EduBot default code and followed the instructions in Kevin's non-bells-and-whistles camera zip archive.
Note that it is not sufficient to follow the "Using last years rc" text file because the full size RC code is not directly compatible with the EduRC.
Unread 25-01-2006, 20:30
Mike's Avatar
AKA: Mike Sorrenti
-Kevin
This code works perfectly
It tracks beautifully, I think I speak for everyone when I say thanks
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Strange products upon running code... neilsonster Programming 17 10-08-2005 00:20
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
