Go to Post Blasphemy! Everyone knows Mountain Dew is roboteer fuel. - Racer26 [more]
Unread 25-01-2006, 22:45
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Re: Anyone Thought of This?
Originally Posted by Radiator251
We had an idea for a new transmission to power train chain assembly, and we're wondering if anyone's ever used this before, and if so, has it worked? Thanks.
What are your thoughts on this design?
Why are you sharing it?
Why do you think this design is worthwhile?
Share some more of your thoughts - it will get you more feedback!
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 25-01-2006, 22:50
I'm no mechanical engineer, but by driving the front 2 wheels off the same chain, you are reducing the amount of sprocket teeth off the transmission "sunk" into the chain from about 1/2 to 1/6.
My opinion... I wouldn't trust it. Those CIM motors are pretty torquey, and if you hit someone hard im not sure if you would break something.
But then again, it is #35 chain.
Ahh, the beauty of design decisions!
Unread 25-01-2006, 22:54
Radiator251 Radiator251 is offline
Programmer
AKA: Jason Raede
FRC #1717 (Dos Pueblos)
Radiator251 is an unknown quantity at this point
We wanted, as we are a rookie team, to determine whether the lower amount of chain necessary for this design (as opposed to the split design with the transmission driving both rear wheels). We are especially concerned about the pressure on the transmission sprocket and the requisite % of the transmission sprocket that must be actively contacting the chain. Thanks for your advice.
Unread 25-01-2006, 23:36
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
I'm pretty sure our team used something similar last year with the same motor and wheel setup for a 6-wheel design, only we powered all 3-wheels on each side by a single chain. We used a roller between the middle wheels and wheels farthest from the motor to make the chain lower, that way the chain would catch on more teeth on the drive sprocket.
Unread 25-01-2006, 23:53
Two things on this--One is your tranny-to-wheel setup. The only thing I can say is: You're pushing it. Be prepared to use the split setup, but test your robot hard ASAP to make sure. Two, using #35 on the back is OK, but using a lighter chain (say, #25) in front is iffy. We've had bad experience and now use it only for prototyping, if at all. You may be able to get away with it though. Once again--TEST! Don't wait until Thursday at L.A. to find out that something doesn't work.
Unread 25-01-2006, 23:56
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
What i would tell you to do is have 2 sprockets attached to your ourput shaft. One that goes to the lead wheel. And then one that leads to the middle wheel. Then from the middle wheel power your back wheel (as you have in the picture.) That way if one of the chains pops in a match you are still life with at minimium of 1 wheel on that side still driving, so you aren't a sitting duck in the middle of the field. But overall its pretty sweet.
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
Unread 26-01-2006, 10:16
Originally Posted by Tim Delles
What i would tell you to do is have 2 sprockets attached to your ourput shaft. ....
I REALLY like this approach. Nothing breaks your heart more than seeing a bot on the field, going in tight circles, and you can see a motor spinning the air and nothing else.
Unread 26-01-2006, 10:38
Mr.G Mr.G is offline
AKA: Kevin
FRC #0326 (Xtreme Eagles / Romulus High School / General Motors)
Mr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond repute
Send a message via AIM to Mr.G
Are you steeling our design.
I think you idea is great and worked for us last year.
Licensing Questions WebWader125 Inventor 2 03-11-2005 12:33
#1 The Journey of a FIRST Graduate: Questions Ken Leung General Forum 12 27-07-2005 18:24
Common Questions with Repeating Answers Tom McCurdy General Forum 1 20-01-2005 15:06
Crazy NEW Idea! Kyle Love Championship Event 14 07-11-2004 16:50
my idea of a question forum... Ken Leung General Forum 12 30-11-2002 12:17
