Go to Post I'm not sure why, but I'm getting this picture in my head of a bunch of engineers, huddled in deer blinds with 22's, waiting for the right power wheels toy to drive by. - Tom Line [more]
Unread 25-01-2006, 19:39
gnirts gnirts is offline
Suspicious pointer conversion
AKA: Robinson Levin
FRC #1648 (The Gearbox Gangstaz)
gnirts will become famous soon enough
Question Issues with MPLAB 7.30
At http://www.ifirobotics.com/rc.shtml (all the way at the bottom) it said not to use a MPLAB Version greater than 7.20:
NOTE: To Compile 2004, 2005 or 2006 code, use MPLAB ver 7.20 and C18 Compiler ver 2.40 (newer versions can not be used)
Does anyone know why?
I ask because MPLAB 7.30 supports Subversion (for version control), while 7.20 does not.
Thanks in advance,
Robinson
'... who are you, then?'
'I am part of that power which eternally
wills evil and eternally works good.'
Goethe, Faust
Unread 25-01-2006, 20:05
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: Issues with MPLAB 7.30
I use version 7.21, and it works fine thus far. It may simply be that it is unsupported.
Unread 25-01-2006, 20:09
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Newer versions of the C18 compiler cannot be used. It's fine to use a more up to date MPLAB.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 25-01-2006, 20:22
AKA: Robinson Levin
Smile Re: Issues with MPLAB 7.30
Thanks.
Tested a few versions of the code with 7.30, works fine (as does svn!)
Goethe, Faust
Unread 25-01-2006, 22:57
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
SVN is nice.
Yes, 7.30 works, although the compiler that comes with it might not work.. which would be the problem.
MPLAB C18 problem Justyn Programming 0 09-03-2005 11:37
MPLAB Variable Simulator? Chris_Elston Programming 3 18-02-2004 12:08
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
