Go to Post Sir, you vastly underestimate the destructive power of a teenager. - DonRotolo [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 24-01-2006, 18:28
natis's Avatar
natis natis is offline
natalia
AKA: natalia soberanes
FRC #0987 (High Rollers)
natis has a spectacular aura aboutnatis has a spectacular aura aboutnatis has a spectacular aura about
Send a message via MSN to natis
Attaching Treads to IFI Wheel
Does anyone know alternative ways to attach the threads to the IFI wheels ??
we appreciate your help
Unread 24-01-2006, 18:45
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: different way to attach threads
I think you mean treads, not threads.
Unread 24-01-2006, 19:35
occra 23.
AKA: ryo
None #1481
i would expect gorilla glue to work too. any reason behind not pop rivets? we just learned how to use them.
Unread 25-01-2006, 22:06
Woodie Flowers Award
Ken Patton Ken Patton is offline
purple
FRC #0051 (Wings of Fire)
Ken Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond repute
We found that the pop rivets supplied by IFI worked very well. We had an "assembly line" of 4 students: one marking, one drilling, one pre-placing rivets and eating Chex mix, and one using the rivet gun. Did 7 wheels in a little more than two hours.
Don't forget to make sure the end of the rivet gets through the wheel rim before you start squeezing - this was a common problem when we started.
We used the wheel rim itself as the template for marking the belts for drilling, and it worked well.
Can't wait to experience the high traction of these wheels. We feel sorta lame knowing that ours aren't anodized, but maybe we'll just put an IFI sticker on the quarter panel...
Ken
Unread 25-01-2006, 22:39
Jay Trzaskos's Avatar
Jay Trzaskos Jay Trzaskos is offline
Jay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond repute
Ken, I'm sure we Ken get our machinist to annodize them for you on thursday night at GTR. What a great way to spend a weeknight in Canada.
JT
229
Jay Trzaskos
Product Design Engineer
University at Buffalo - MAE 2012
Alumnus - Theta Tau, Mu Gamma Chapter
Unread 25-01-2006, 23:58
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
Re: Attaching Treads to IFI Wheel
Ken is right. The best way way that we have found is pop riveting them, it works wonders. Also make sure the tread is tight when you rivet it in place.
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
Unread 26-01-2006, 01:44
AKA: Dr. Brooks
no team (WRRF)
We machine our own rims using cast wheels from McMaster, but we use the same waffle tread. We bead blast the aluminum for a good glue surface. We take a belt sander (80 grit, I think) to the back of the waffle tread, taking off the low friction (also low adhesion) nylon backing and being very careful to just get to the first black rubber layer. We then clean the wheel and the rubber well with MEK, we clean it many times to prepare the surface for glue. We then use very long cure super glue, stretching the tread into place on the wheel, and zip kick it. After the glue is cured, pulling the tread off leaves black rubber on the wheel. Haven't needed any rivets or screws yet...
Have fun,
Eugene
Unread 26-01-2006, 08:35
Smrtman5's Avatar
Smrtman5 Smrtman5 is offline
Dr. Bridgeport
AKA: Jon H
FRC #0041 (Robo-wariors)
Smrtman5 is on a distinguished road
Send a message via AIM to Smrtman5
We started with one side unassembled. The tread was held in place to the wheel with a pair of vise grips and we used a red hot sharpened piece of metal to form the hole in the tread my pushing it through the hole in the wheel. (Note: the smoke of the burning tread was unpleasant. We faced a fan out the open door to remedy the problem) After one rivet was in place, we clamped the other end of the tread, making sure it was taught around the wheel and repeated the process for all the rivets.
Art is just an excuse for poor craftsmanship.
- Jon H
Team 41
Rowan University '10 Mechanical Engineering
Unread 05-02-2006, 21:07
pacoliketaco's Avatar
pacoliketaco pacoliketaco is offline
Alumni
FRC #1807 (Redbird Robotics)
pacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to behold
Send a message via AIM to pacoliketaco Send a message via Yahoo to pacoliketaco
i am pretty sure we used 4 screws to attach the two ends into the original rivet holes. Then we used caulk to keep them on. we also lock tighted all of the screws that attach the rims to themetal tread.
Pace Nalbone
Carnegie Mellon University
Mechanical Engineering Class of 2013
2009 NYC Winner - 56 and 1796
(2009 Regional Record: 18-0-7 wins/ties/losses)
Attaching sprocket to wheel sdcantrell56 Technical Discussion 3 15-01-2006 19:21
How did you control your Robot? 1? 2? Wheel? How? ChrisCook Control System 9 17-05-2005 21:41
Has 6 wheeled designs surpased tank treads Andrew Schuetze Technical Discussion 60 27-04-2005 17:29
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
