Re: Labview keeps freezing
Thanks! -Joe |
I tried the previous GUI again; this time, it loaded 3 frames before dying. I suspect that one side or the other loses the serial channel intermittently. |
I've had the same issues with Labview. I've used different batteries as well as a 12v regulated/filtered supply. All versions of the software have behaved in the same fashion.
UPDATE. By using the latest update posted by Joe, I was able to get through a sucessful calibration session with the camera. It still posted some "unable to communicate...check serial port..." messages a few times, but I just closed the window and kept working, ignoring the error. The camera still responded after doing this.
One new oddity came up while doing this. The pan function seemed to be reversed. It wanted to track AWAY from the light source. Tilt worked properly. Since this can be addressed in the rc code, I simply unplugged the servos in order to complete calibration. Thanks Joe. glenn |
When you get the error message does it grab part of a frame? -Joe |
glenn |
#7
Are you saying that the new version does nothing? I really don't understand what you mean when saying Quote:
When you say "previous GUI", are you referring to the Java GUI from last year or are you referring to one of the previous LabVIEW releases? Have you checked your change on the backup battery and all the wires for breaks or loose ends? -Joe |
#8
For us, the 1/25 version eliminated the run-away progress bar behavior that version 1/17 exhibited.
Peter H came over to play last night and we were able to grab frames repeatedly from his camera, but with my laptop. Last edited by Mark McLeod : 27-01-2006 at 10:47. |
#10
Sometimes, I can Grab Frame OK. The rest of the time, I Grab Frame, the red LED flashes, the blue progress bar advances to the end, the progress bar disappears, a partial frame shows, and an error box appears "The application is closing because of a reported error ...". The status code is -1073807252. The status source is "VISA Read in get picture.vi>CMUcam2.vi>CMUcam2GUI.vi" I had to expand the status box to read this. I can click on the error box, it disappears, and the run icon reverts to not running. I can click on the run icon again, and repeat the process - sometimes it works, sometimes not. What is my problem? |
#11
I'll look at the code to see if there is anything that can be done to make the program less susceptible to the problem. One solution is to lower the Baud rate (which would need to be done both on the camera and in the application / MAX) but would make the frame grabbing even slower. Hopefully we can avoid having to do that. Cheers! -Joe |
#12
If this is a buffer size problem, why does it work more often than not? When I get a partial frame, it is anywhere from 10% to 90% of the full frame. |
#13
or operating systems like Windows that are not real-time, it is difficult to service every byte with low latency (before the next byte). It is much easier for something like the PIC in the RC.If it works more often than not, then VISA is barely not able to keep up with the serial stream. This should only be an issue for receiving, so you shouldn't have problems with things like programming your RC. You may have problems if you try reading the memory at full speed. I will add an option in the code to allow you to make it work for your serial port and computer. It will slow down the rate at which the camera sends bytes to you and will eliminate the buffer overflows (as long as you set it high enough). You will want to start with 1 bit delay (the default is 0 which is causing your problems) and increase it until your problem goes away. Since it almost works now, I would expect that a value of 1 or 2 should be sufficient to make it work very well. At least I'm confident that this should solve the problems you and others have been having. Thanks for helping to diagnose the problem so that everyone can enjoy the benefits of a working system! I'll post it when I finish the addition. Cheers! -Joe |
#14
Peter,
I've posted the new version. Please let me know if it solves your problem. Thanks, -Joe |
#15
My earlier post was misleading. The serial port buffers are set to 14 and 15. I had thought you meant a software buffer. And many (~50?) WinXP processes are running in the background; most, I have no idea what they do. Maybe one of these sometimes prevents LabView from fetching the data? I can operate LabView CMUcam2 GUI reliably on my desktop; Grab Frame works 20 times out of 20. But that is faster, with fewer background processes. |
| Example LabVIEW Apps - Dashboard, CMUcam2 and Motors | Russ Beavis | National Instruments LabVIEW and Data Acquisition | 9 | 21-01-2007 17:19 |
| LabVIEW Com Port Error | 354.FIRST | LabView and Data Acquisition | 4 | 18-01-2006 18:43 |
| National Instruments LabVIEW and Data Acquisition Forum | Danny Diaz | National Instruments LabVIEW and Data Acquisition | 1 | 16-01-2006 13:20 |
| COM port settings for CMUcam labview testing and programming | pwilczynski | Programming | 1 | 15-01-2006 15:09 |
| National Instruments LabVIEW & Data Aquisition Forums | Brandon Martus | Announcements | 0 | 22-11-2005 21:12 |
