Go to Post Yes indeed... ten years ago tomorrow, those famous words "water game" were first mentioned on Chief Delphi! Oh, how things have and have not changed... - bduddy [more]
Unread 25-01-2006, 22:43
Idaman323 Idaman323 is offline
In Theory, Our Robot Would Own.
FRC #1706
Team Role: Driver
Idaman323 is an unknown quantity at this point
CMUCam2 GUI Tilt Question
Hey, I finally got the camera working, the LabView didn't work for more than 5 minutes before it gave us errors. So I switch to the CMUCAm GUI. I got it default, turned the automatic servo movement on, then picked a color, and tracked it. The camera moved left right just fine, but when we raised the color up and down, the camera did not tilt at all. Also, when the color gets raised, the square on the tracking screen goes down. Like its inverted. When i tried changing the invert setting, the camera didn't track the color anymore. And now the tilt doesn't work.
PS. Does anyone know if we have to color calibrate the camera when its on the robot. And if we do, do we calibrate the color while at the competition?
TEAM 1706
2007 Judges Award, St. Louis (For our amazing ability to have bad luck)
2005 Rookie Inspiration Award, St. Louis
Unread 26-01-2006, 01:41
Joe Hershberger Joe Hershberger is offline
National Instruments
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
Re: CMUCam2 GUI Tilt Question
If you're interested in trying LabVIEW again, please test the version from 2006.01.25 here and let me know what your results are. Perhaps we can figure out what the problem is.
Thanks!
-Joe
Unread 26-01-2006, 18:57
FRC #1706
Team Role: Driver
I tried the updated version and it gives me an error when I hit the run button. Ir says I think ERROR: 7. Im not sure what it was, because Im not at that computer right now
And now, apparently, the camera board, was mounted on upside down.. Someone else put it together wrong. So I fixed that and now the servos turn away from the object. It sees it then moves the opposite direction. The tilt still doesn't work though. I set the setting on the CMUCam2 GUI to "Invert Tracking" and in the Color tab, when I start trackeing, the whole box turns blue and the camera doesn't move at all. Im getting confused Hopefully when I hook it up to the robot it all works.
TEAM 1706
Unread 27-01-2006, 02:01
AKA: jhersh
Let me know what the error is for sure when you are at the computer again.
Thanks
-Joe
CMUcam2 Serial Port Diagnostics Kevin Watson Programming 13 18-02-2006 15:05
LabView CMUcam2 gui drakesword LabView and Data Acquisition 6 28-01-2006 17:06
CMUcam2 LabVIEW GUI problems StevenB Programming 1 21-01-2006 03:08
CMUcam2 GUI Program nukem Programming 4 15-01-2006 03:19
ChiefDelphi Forums Community Bulletin Brandon Martus CD Forum Support 0 05-05-2002 22:07
