Go to Post Girlfriend? What is that? A rare Pokemon? - DanielPlotas [more]
Unread 26-01-2006, 02:13
blue_crew blue_crew is offline
MADTOWN ROBOTICS!!
AKA: Daniel Sheeter
FRC #1323 (Madtown Robotics)
blue_crew is on a distinguished road
Send a message via AIM to blue_crew Send a message via MSN to blue_crew Send a message via Yahoo to blue_crew
T-Slot extruded aluminum
I have read a lot about t-slot extruded aluminum and their advantages (versatility, range of options, prototype ability) and drawbacks (weight, cost) but i haven't found any figures on just how expensive this stuff is per foot.
I am looking at either 1"x1" 80-20 or 30mm x 30mm bosch or item.
I understand fasteners are even more but i just want to know a ball park figure.
This is for the upper level of the robot and will be used to build the hopper and flywheel mounts and will extend up from the kitbot chassis.
Unread 26-01-2006, 02:50
UlTiMaTeP UlTiMaTeP is offline
UlTiMaTeP will become famous soon enoughUlTiMaTeP will become famous soon enough
Re: T-Slot extruded aluminum
3-4 dollars depending on how much you buy for 1x1, www.mcmaster.com page 1522
Mcmaster is your friend for anything mechanical
The major advantage is that it has very strong fasteners that do not need to be welded and the fact you can slide it around without having to set on a definite shape.
As for strength and shape, the major advantage of this is the T shape, it resists bending very well, and just slightly less it resists torque better than standard square extrusion.
Hows my searching? Call 1-800-Green-Dots
Unread 26-01-2006, 03:14
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
the fasteners get very expensive, very quickly.
If you don't mind doing some cutting, and cleaning up of threads, you can save quite a bit of money by going to your local hardware store and buying a ton of toilet bolts instead of t-nuts.
2001-2004: Team 100
2006-Present: Team 254
Unread 26-01-2006, 08:28
Smrtman5's Avatar
Smrtman5 Smrtman5 is offline
Dr. Bridgeport
AKA: Jon H
FRC #0041 (Robo-wariors)
Smrtman5 is on a distinguished road
Send a message via AIM to Smrtman5
10/10 Costs about $.21 an inch. If you look through the 80/20 website ( www.8020.net ) there is a price list, it just requires a bit of searching.
Art is just an excuse for poor craftsmanship.
- Jon H
Team 41
Rowan University '10 Mechanical Engineering
Unread 26-01-2006, 08:45
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
As a follow up to the pricing, 80/20 do give a 50% discount to all FIRST Teams. You need to state that you're with a FIRST Robotics team, and then make sure that the salesperson you are dealing with is aware of the discount as well.
We've been using 8020 for the past three years and love it! Very easy to assemble, modify, replace, and maintain. The weight isn't as bad as everyone thinks. The weight of 1010 is with 5% of 1" (.125 wall) Al square tube. AND, it's stiffness in bending and torsion is within 5% as well. The extra weight of the connectors will be about 2lbs for us this year. So, a little extra effort up front to save weight will certainly pay off with the flexibility of this product.
I'll quickly quote some full prices for you. (You can do the math for the discount.)
Profiles
1010: $.21/inch
1515-lite: $.42/inch
Cut Charges (For pieces shorter than 144")
7005: $1.85 (1010 profile)
7010: $1.85 (1515 profile)
Connectors
3090: $1.20 (Double Anchor for 1010)
3098: $5.50 (Double Anchor for 1515)
Feel free to ask more questions about extruded profiles. OH, we've found that paying for them to cut the pieces to lenght FAR outweighs the cost of having a full lenght piece sent! Good luck!
BEN
P.S. We've never "broken" a piece of 8020, that's absurd. As I've mentioned above, the 10-profile of 8020 is of the same weight, strength, and stiffness of a 1" square al tube. The joints can be a weakness, if not properly made. The same can be said about a welded square tubing frame. To properly assemble 8020 extrusions, the ends must be machined square and perpendicular, no hack saws here! And end mill on a milling machine is the best way to achieve this. For the connetors, we've always used the double anchors (see above.) These handle far more load than the 90 degree brackets, the single anchors, and the drill and bolt together method. And, will these extrusions handle a "fall" from the platform, most certainly. Please, contact 8020 (or similar companies) and ask for a free demo. They'll bring a truck straight to your door, full of profiles, connectors, brackets, and loads of other fun stuff. You won't be disappointed.
Unread 26-01-2006, 09:20
Ken Loyd Ken Loyd is offline
Who is John Galt?
FRC #0039 (The 39th Aerosquadron)
Ken Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to behold
Daniel,
Several years ago (4 I think) we used the T-slot for our base. We were not overly excited about its' performance for a base. This year we are using the base from the kit of parts. We are using the T-slot for our harvester and launcher platform. T-slot works well for us as for add ons to the robot. Make duplicate parts because in the heat of competition, the T-slot will sometimes break.
Ken
Ken Loyd
Teacher/Advisor
Team #39
Highland High School
Unread 26-01-2006, 09:27
MADTOWN ROBOTICS!!
AKA: Daniel Sheeter
Originally Posted by Ken Loyd
Daniel,
Ken
We used the kitbot base last year and were very happy with it and are sticking with it this year. Are you using 1" x 1" for your harvester and launcher or something more hefty? Is 1" x 1" strong enough to withstand a fall if the robot tips?
Thanks for all the answers!
Unread 26-01-2006, 10:09
REVving up for a new season
FRC #2848 (All-sparks)
In addition to the 8020 deal itemamerica.com offers packages at discounts for FIRST teams. I have never compared the deals between the 2 companies but i like to give people options.
Here is a list of their deals for FIRST teams for 2006.
http://www.itemamerica.com/FIRST2006.pdf
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 26-01-2006, 10:37
Jared Russell's Avatar
Taking a year (mostly) off
We've used 8020 products for several years now - the only problem has been weight at times. It's very nice to be able to slide assemblies around the robot during build and testing, when unforseen "features" of our robot rear their head. Once everything is where you need it, you can drill through the extrusion or tap weld for extra strength, but we've fallen off of ramps 5 ft tall and never had structural damage with the 8020 line.
Unread 26-01-2006, 11:48
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Just an FYI. We have never used any 80/20 (or other brand) before but are strongly considering it this year. I called 80/20 directly yesterday and they referred me to our distributor who was very helpful and was quite familiar with FIRST teams and checked on the discount. The distributor for our area is Bertelkamp Automation in Knoxville, TN and we were quoted only a 40% discount for FIRST teams. Still a great discount! Your millage may vary.
BTW: We are looking at the 80/20 Quick Frame line which is different than the T-Slot stuff. It is the smallest/lightest and cheapest stuff they make. It is basically 1" AL square tube with press fit connectors. The only tools required are a miter saw and a rubber mallet. I have never actually seen it or handled it in person but from the catalog and specs it looks like it might work well for our application. I doubt I would use it for high structural loads though.
Does anyone have any experience with the 80/20 Quick Frame product line?
Unread 26-01-2006, 12:40
Dom Ruggieri's Avatar
Dom Ruggieri Dom Ruggieri is offline
FRC #1676
Dom Ruggieri is an unknown quantity at this point
We are using the item profile 5 extrusion which is 20x20mm and is about $2 a foot. We built a chasis out of it and it only weighs about 14lbs, but the nuts and bolts are about $20 for 100. it is deffently worth it to built with the extrusion and i think the item is a lot better then the 80/20.
Unread 26-01-2006, 13:56
Who is John Galt?
Daniel,
We are using the standard 5/16" slot.
We also are keeping the majority of the weight as low as possible on the robot. Our overall height will be about 36". We don't expect to be very "tip-able". We will use gussets (thin aluminum plate) at the critical joints for added strength.
Ken
Ken Loyd
Teacher/Advisor
Team #39
Unread 26-01-2006, 18:29
occra 23.
AKA: ryo
None #1481
we tried using it as our whole robot 2 years ago but now we hate it. too heavy. too hard to use. standard 1/4 in bolts and angle alumiunm work better i htink.
Unread 27-01-2006, 10:43
Dick Linn's Avatar
no team (Synergy)
We've had great luck with regular 1" x 1" x 0.125" square tube for our frame and drive platform. It's $1.28 per foot. We make small top and bottom connector plates from 1/8 plate and fasten with a few 10-32 socket head cap screws which are strong, light and about 10 cents each.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 27-01-2006, 12:41
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
I would recomend NOT using Bosch 30x30 or 20x20. My old team used this a few years, and the chassis was always heavy and expensive. Bosch is metric, so you have to use metric bolts and you have to buy the special T-nuts, which are rather expensive. Also, the connectors are expensive, and rather weak, especially for 20x20. I can estimate that our Bosch chassis from 2003 was around 600 dollars with all the bolts and beams and connectors, and weighed a solid 30 lbs, and was still kind of weak.
If you are looking into extrusion, try to go for something customary. Bosch sells an inch series, and there is also 8020 and lots of other extrusions that are in inches. Inch series is less annoying to work with (no conversions, as FIRST is generally inch-based), and less expensive because there are more common parts, like bolts and T-nuts.
Using Extruded Aluminum to telescope. LGuY Technical Discussion 21 07-02-2005 12:43
Torsional Stiffness of Extruded Aluminum Ben Piecuch Technical Discussion 3 19-01-2005 21:55
where can I get info on extruded aluminum? SCYTE16 General Forum 21 13-01-2005 14:23
Mini extruded aluminum Ravi U Technical Discussion 7 17-01-2004 02:12
