Go to Post Lawyers find loopholes. Engineers find solutions. For which would you rather be known? - dlavery [more]
Unread 25-01-2006, 22:41
Radiator251 Radiator251 is offline
Programmer
AKA: Jason Raede
FRC #1717 (Dos Pueblos)
Radiator251 is an unknown quantity at this point
Questions about an Idea for a drivetrain.
We had an idea for a new transmission to power train chain assembly, and we're wondering if anyone's ever used this before, and if so, has it worked? Thanks.
Unread 25-01-2006, 22:45
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Re: Anyone Thought of This?
What are your thoughts on this design?
Why are you sharing it?
Why do you think this design is worthwhile?
Share some more of your thoughts - it will get you more feedback!
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 25-01-2006, 22:50
I'm no mechanical engineer, but by driving the front 2 wheels off the same chain, you are reducing the amount of sprocket teeth off the transmission "sunk" into the chain from about 1/2 to 1/6.
My opinion... I wouldn't trust it. Those CIM motors are pretty torquey, and if you hit someone hard im not sure if you would break something.
But then again, it is #35 chain.
Ahh, the beauty of design decisions!
Unread 25-01-2006, 22:54
Programmer
AKA: Jason Raede
We wanted, as we are a rookie team, to determine whether the lower amount of chain necessary for this design (as opposed to the split design with the transmission driving both rear wheels). We are especially concerned about the pressure on the transmission sprocket and the requisite % of the transmission sprocket that must be actively contacting the chain. Thanks for your advice.
Unread 25-01-2006, 23:36
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
I'm pretty sure our team used something similar last year with the same motor and wheel setup for a 6-wheel design, only we powered all 3-wheels on each side by a single chain. We used a roller between the middle wheels and wheels farthest from the motor to make the chain lower, that way the chain would catch on more teeth on the drive sprocket.
Unread 25-01-2006, 23:53
Two things on this--One is your tranny-to-wheel setup. The only thing I can say is: You're pushing it. Be prepared to use the split setup, but test your robot hard ASAP to make sure. Two, using #35 on the back is OK, but using a lighter chain (say, #25) in front is iffy. We've had bad experience and now use it only for prototyping, if at all. You may be able to get away with it though. Once again--TEST! Don't wait until Thursday at L.A. to find out that something doesn't work.
Unread 25-01-2006, 23:56
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
What i would tell you to do is have 2 sprockets attached to your ourput shaft. One that goes to the lead wheel. And then one that leads to the middle wheel. Then from the middle wheel power your back wheel (as you have in the picture.) That way if one of the chains pops in a match you are still life with at minimium of 1 wheel on that side still driving, so you aren't a sitting duck in the middle of the field. But overall its pretty sweet.
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
Unread 26-01-2006, 00:11
FRC #0701 (RoboVikes)
I wouldn't trust it,
my team isn't very good at lining things up perfectly, and if that things is not lined up perfectly it will probably give alot more easily than a setup which has 50% tooth contact.
Plus it is really not saving that much room or weight... maybe 1 sprocket.
what we did last year and this year is put 3 sprockets on the center wheel, (they don't have to be all hubbed you can use plate sprockets). 1 sprocket connects to tranny, then 1 goes to front, and one to back. This is a lot more robust, plus if you break one chain you still have 4wd, (unless of course it is the chain from your drive to center...then you're screwed)
Team 701
Unread 26-01-2006, 01:31
CraigHickman
Posts: n/a
From your drawing, you're going to have problems off the bat with amount of chain gripped by the drive sprocket. It would end up being better to just have a small loop being the 35 chain, and that loop being back motor to back wheel. From there you could put a 25 chain size sprocket onto the back, middle, and front wheels. This would mean that the back and middle wheel would have 2 sprockets each. In order to cut down on weight, you can use 25 chain for the linking of the wheels, and only use 35 for motor to back wheel transmission.
As for the concern stated about 25 chain not being strong enough, We have used it on all of our drive trains for the last 2 years, and not had any problems, as long as you design the system correctly.
One other small tip: Don't forget tensioners! Regionals are a lot more fun on the field, versus in the pit sixing a chain that popped off!
Unread 26-01-2006, 08:47
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
I like the weight saving idea of the #25 chain to the front wheels. The biggest concern I see is the wrap of the chain on the drive motor sprocket. I would not trust the design as shown in your sketch, but if you used two small idler sprockets on the outside of the chain you could kill two birds with one stone. If the idler sprockets are mounted just below the motor and kinda close to each other you should be able to get close to 180 degrees of wrap on the drive motor sprocket. Basically the chain going over the top sprocket needs to look more like an upside down 'U' instead of an upside down 'V'. the other thing about the idler sprockets is they will make a good tensioning device. That's just my $.02 overall a good weight saving design that just needs some massaging.
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
Unread 26-01-2006, 08:53
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
I would also be concerned about the small amount of wrap around the motor sprocket. Another possible way to improve that would be to put an idler sprocket just below the motor output sprocket. You could rout the chain 180° around the motor sprocket then over the top of the idler and around the idler and back to the other wheel sprocket. Maybe you could even use the idler sprocket as the chain tensioner.
Or you could eliminate chain all together. We have used no chain on our robots since 2003.
Unread 26-01-2006, 09:23
John Neun John Neun is offline
FRC #0020 (Rocketeers)
John Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond repute
We have used a similar arrangement with good success. Some things we have learned:
I concur regarding drive sprocket chain wrap. Try to approach at 180 degrees. You won't get that much, but shoot for wrap as a single pair. If you use a single chain for both middle and front wheels, you need an idler as suggested to increase drive wrap.
All 035, all the time. Even if you use a single CIM to drive (we use pairs), the 025 will be a thorn in your side. We learned that the hard way two years ago. It's well worth the weight. A robot that can't move isn't a robot. It's just furniture.
We opted to use a "live" center shaft to drive the center wheel last year, and slaved the front and back wheels to the center wheel. This made for a third chain and more complex machinery, but it let us put the transmissions where we wanted them. I think two chains with an idler wrap is a more efficient approach, much as you've drawn. A live shaft is also more complex to build and assemble.
It would be wise to keep the wheel sprocket size a little large, say 30 or 32 teeth. This tends to de-emphasize runout issues in the sprockets.
Good luck!
Unread 26-01-2006, 09:50
REVving up for a new season
FRC #2848 (All-sparks)
To illustrate this idea for you i used paint. This is what i would do if you were going to use a drive system like this.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 26-01-2006, 09:52
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
This is the setup 229 ran last season. We used #35 chain for both sets, but the idler/wheel/transmission setup looked a lot like that. It worked out well for us; and I would probably do it again.
-JV
Unread 26-01-2006, 10:13
Aside from chain problems, it has a pretty high center of gravity, which argues against that layout. First, the idlers would probably weigh as much as another sprocket, and, second, this year keeping CG low is going to be a big problem -- especially if you plan to climb the ramp. Move the motor down inside the frame rails, driving the primary chain to the center wheel, and then run lighter chains (if you want you could just use #35 chain instead) to the front and rear wheels. Titan Robotics (492) has used this VERY successfully for the last two or three years. In fact, this is a lot like what we are doing this year. Our transmissions are only going to stick up about an inch above the frame rails.
Licensing Questions WebWader125 Inventor 2 03-11-2005 12:33
#1 The Journey of a FIRST Graduate: Questions Ken Leung General Forum 12 27-07-2005 18:24
Common Questions with Repeating Answers Tom McCurdy General Forum 1 20-01-2005 15:06
Crazy NEW Idea! Kyle Love Championship Event 14 07-11-2004 16:50
my idea of a question forum... Ken Leung General Forum 12 30-11-2002 12:17
