Go to Post I shouldn't be doing a happy dance or anything, should I? - Qbranch [more]
Unread 26-01-2006, 12:31
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Re: Gyro not accurate - Problem
I think the max rotational velocity is the main issue. I will try and rotate it more slowly to see if this solves it.
can anyone point to other sensors which are compatible but have a higher max rotational velocity limit?
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
atan Problem - Need Help the_undefined Programming 0 18-02-2005 11:16
Physics Problem Venkatesh Math and Science 13 30-11-2004 20:30
No Signal From Gyro colt527 Programming 12 19-10-2004 07:30
Ok one problem cantwell03 Programming 3 13-02-2003 07:28
Have YOU used the gyro chip? FotoPlasma Technical Discussion 10 31-01-2002 13:26
