Go to Post But you are an influencer: Use it for good. - DonRotolo [more]
Unread 26-01-2006, 13:06
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Re: Gyro not accurate - Problem
Originally Posted by KenWittlief
Analog devices has pretty much cornered the market for MEMs solid state gyros.
They have several. The ADXRS300 will track up to 300°/S. I have not looked at the gyro that is included in the kit of parts this year. The ADXRS familiy has analog outputs that must be handled as analog signals into the robot controller.
www.analogdevices.com
Thanks Ken,
I have heard that there are two types of gyros, one that tells you angular speed, and one that tells you angular position.
correct me if i'm wrong, but wouldn't an angular position gyro work better for our purposes and be simpler?
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
atan Problem - Need Help the_undefined Programming 0 18-02-2005 11:16
Physics Problem Venkatesh Math and Science 13 30-11-2004 20:30
No Signal From Gyro colt527 Programming 12 19-10-2004 07:30
Ok one problem cantwell03 Programming 3 13-02-2003 07:28
Have YOU used the gyro chip? FotoPlasma Technical Discussion 10 31-01-2002 13:26
