Go to Post While FIRST's goal is to inspire young people, it will be much easier to do that if we also inspire all the older people as well. - E. Wood [more]
Unread 26-01-2006, 13:15
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Re: Cross Mode Variables?
Originally Posted by dcbrown
My guess is that autonomous is applied to all 'bots on the field, and robot disables are both individual along with a global field disable. So if you are disabled for rules infraction while in autonomous mode, then I'd expect autonomous would be still active but your individual robot would have disabled applied. The robot state would then be !Enabled/Autonomous state.
It might seem esoteric, but what if you wanted to do something in the last 4 seconds of autonomous period... like gain a certain field position... to set up for manual play. Yeah, I know you might not have won the autonomous period so might be putting the robot in the WRONG position but that is part of the fun of selecting autonomous strategy. So, you'd like to know in the code how much time you have left. If you start counting when autonomous is enabled but disabled is still applied then you'd be counting time wrong. I suspect these two input changes happen very close together, but still I'd rather understand the risks associated with states we're ignoring vs get surprises during competition events.
Regards,
DCBrown
It would seem pretty simple to start counting in the autonomous initialization routine, as it will not be executed until the actual autonomous mode starts.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 26-01-2006, 14:34
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
We have a interrupt driven system clock. It is always running in the background and we want it to figure out when to start/stop wall clock accumulation on its own.
Regard,
DCBrown
a simple autonomous mode question chippermonky Programming 3 18-02-2005 01:54
Why did the chicken cross the road? Billfred Chit-Chat 10 29-05-2004 16:11
Future of Autonomous Mode FadyS. Programming 41 24-05-2004 19:45
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
