Go to Post rumors only beget more rumors - JakeGallagher [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition > LabView and Data Acquisition
Unread 26-01-2006, 14:16
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Re: LabView Dashboard Problems
Originally Posted by brummer_13
Yea I got the camera to work just about perfectly but i want to get feedback from my robot itself through labview and i dont know how to do it
Ah, I think I see what you mean. To get feedback to the driver (on things not already relayed to the driver such as PWM values, battery levels, etc...), you need to write to the user bytes within your source code. You can then see those user bytes through the Dashboard. If you're using the IFI Breaker Panel and have it connected to your Program Port, realize the Breaker Panel writes to user bytes so be careful what bytes you use - info on what the breaker panel uses is in the breaker panel documentation (sorry I don't have that info in front of me!).
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Unread 28-01-2006, 14:39
brummer_13 brummer_13 is offline
FRC #1501 (Thrust)
brummer_13 is an unknown quantity at this point
But how do i write to the source code? And how do i also get labview to show me the PWM values and the things already relaed to the driver?
Unread 28-01-2006, 14:55
mfwit mfwit is offline
AKA: Matt Witmer
FRC #1640 (SaBOTage)
mfwit is an unknown quantity at this point
Click Window>Show Block Diagram
Fool around in the block diagram and you will get it.
Unread 28-01-2006, 15:00
FRC #1501 (Thrust)
can u give me alittle more than that, the block diagram is very confusing right now
Unread 28-01-2006, 15:40
AKA: Matt Witmer
if you look at the block diagram, the 4 selector sorta thing down, is the byte that is coming in from your OI. They are all labeled based upon what they are (pwm2, pwm3, etc.). If your looking at one of the pwm bytes that is included with the template, you can copy with what you see on the diagram inside that byte and paste it into a different pwm byte.
Hope that helps,
Matt
Unread 28-01-2006, 21:43
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Ah...ok...I get it now. We aren't using the default IFI Code and MPLAB, we are using EasyC. In EasyC, the user bytes aren't being sent because there is no code written to do so (default template in EasyC). If we had installed the default IFI Code, these user bytes are already included in the default code, I believe.
Thanks guys for helping one of my programmers. He is a freshman and doing very well.
I'll see if I can give him a hand now that I understand what is going on myself. (newbie to Labview)....
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 31-01-2006, 18:29
FRC #1501 (Thrust)
alright now that i know what to do, how do i do it. i cant find anywhere how to change the user byte assignments
Unread 01-02-2006, 09:12
In user_routines.c you’ll see this example line close to the end:
User_Mode_byte = backup_voltage*10; /* so that decimal doesn't get truncated. */
You can also set the following variables anywhere before a putdata()
  • User_Byte1
  • User_Byte2
  • User_Byte3
  • User_Byte4
  • User_Byte5
  • User_Byte6
So for example: User_Byte1 = 123;
Unread 01-02-2006, 20:13
FRC #1501 (Thrust)
  • User_Byte1
  • User_Byte2
  • User_Byte3
  • User_Byte4
  • User_Byte5
  • User_Byte6
where is user_routines.c though, i found the file on my comp but i cant open it with wnything. is that what u ment or is it a part of easyc or something
Example LabVIEW Apps - Dashboard, CMUcam2 and Motors Russ Beavis National Instruments LabVIEW and Data Acquisition 9 21-01-2007 17:19
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
Problems tracking with CMUCam2 in LabVIEW PhilBot LabView and Data Acquisition 5 17-01-2006 20:42
National Instruments LabVIEW and Data Acquisition Forum Danny Diaz National Instruments LabVIEW and Data Acquisition 1 16-01-2006 13:20
Custom Dashboard code for LabVIEW ready for download. archiver 2001 3 24-06-2002 00:49
