Go to Post Let’s not scare the newbies away, let’s welcome them and help them. - Arefin Bari [more]
Unread 26-01-2006, 15:17
Re: Gyro not accurate - Problem
Originally Posted by KenWittlief
you can also let the bot sit still for a few seconds at power-up, and read the 'not moving' output of the sensor. That will be your zero point (might be 126 or 130... instead of 128). This way you compensate for drift, and you have control over the 'calibration'.
This is a really good (hint) suggestion. Remember that you have power to your robot when you set it up for autonomous. There is no reason to wait for the referee to turn on your motor controls to "fire up" and set the "not moving" value of the gyroscope. (Thanks to the Titan Robotics Club, FRC 492, for teaching us about this in the off-season.)
atan Problem - Need Help the_undefined Programming 0 18-02-2005 11:16
Physics Problem Venkatesh Math and Science 13 30-11-2004 20:30
No Signal From Gyro colt527 Programming 12 19-10-2004 07:30
Ok one problem cantwell03 Programming 3 13-02-2003 07:28
Have YOU used the gyro chip? FotoPlasma Technical Discussion 10 31-01-2002 13:26
