Go to Post And, just for the record, dlavery is on my mental ignore list from September until January if the thread involves the word "hint" at all. - Andrew Schreiber [more]
Unread 24-01-2006, 01:26
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Globe motor modification
Is it legal to modify the gearbox of the globe motor?
I needed to speed up the output shaft, so I tapped out the pins holding the planetary gearbox on, removed one of the reduction stages, made a spacer for the shaft, and tapped the pin holes and screwed it back together. I am guessing this is legal because it's legal to remove the gearbox. Any ideas?
Unread 24-01-2006, 01:35
AKA: Dr. Brooks
no team (WRRF)
Re: Globe motor modification
You may modify and build your own gear boxes. It is only the "motor" part that you may not modify. Just to ask, how much of a speed increase did you get? Our globe is running a little slow as well...
Unread 24-01-2006, 07:29
Veselin,
I have not heard this question asked before and it should be put to the Q&A. The rules state, under R36, "The gearboxes for the Fisher-Price, and Globe motors are not considered “integral” and may be separated
from the motors. FIRST will not provide replacements for parts that fail due to modification." I believe the gearbox is also available separately as a single component. As such it would fit under the acquired and modified language making it a "fabricated item" subject to rules and flow chart for that item. Thinking outside the box again, aren't you?
Unread 24-01-2006, 07:50
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
We are doing almost the same thing this year, but instead of using a spacer we put the gearbox housing in a lathe and shortened it by the width of one stage. One of our students is panning to write a whitepaper with the details but is may take a little while. if anyone is interested you can drop me a PM or email.
Matt B.
Unread 24-01-2006, 07:51
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
This is a great trick. We also did this on our 2004 bot because we needed higher RPM and torque wasn't really an issue.
No issues with inspectors once we pointed out the rule. They thought the shortened gear box looked funny.
I'm glad to hearsome one else is doing it. Now if only I could figure out what it's for...
Unread 24-01-2006, 08:21
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
We were just looking at the same thing last night (shortening it). I don't see how there would be any issue, since plenty of precedent exists for modifying the output shafts of Globe gearboxes, and the F-P gearboxes, which FIRST seems to treat similarly.
Unread 24-01-2006, 08:50
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
I am confident that it is legal as well. I can think of no rule interpretation that would make this illegal. This is no different than teams modifying the FP transmissions which is very very common.
Joe J.
Team #88, TJ2
Unread 26-01-2006, 14:00
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
I'd like to know also.
Using the planetary stage reduction formula (R/S) + 1 for each stage, where R is the number of teeth in the ring gear and S in the number of teeth on the sun gear, and counting the teeth as follows:
First stage S = 21, R = 59, second stage S = 13, R = 59, output stage S = 13, R =59,
I get motor stage reduction = 3.8095:1, second stage reduction = 5.5385:1, output stage reduction = 5.5385:1, so the overall reduction is the product of these, or 116.855:1, which agrees closely with the published figure 117:1. The published free speed is 81 +/- 7 RPM
Veselin, did you remove the first stage and replace the motor pinion with a 13 tooth one made from the first stage planet carrier? In that case you'd get overall reduction 30.675:1 for a new free speed of about 310 RPM.
Or did you remove the second stage, giving a new overall reduction of 21.099:1 for a new free speed of about 450 RPM?
Will someone please check my analysis above?
Richard Wallace
since 2003
Unread 26-01-2006, 14:04
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
assumption....he removed the second stage.
as far as i remember this removal trick can only be done by removing the second stage.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 26-01-2006, 15:00
AKA: Matt
On ours we removed one of the 5.5:1 stages. We tached the free speed of the shaft after modification at ~ 480RPM.
Matt B.
Unread 26-01-2006, 15:01
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Did Some Rule searching
Originally Posted by [url="http://www.usfirst.org/robotics/2006/frcdocs.htm"
The 2006 FIRST Robotics Competition Game Manual[/url]-Section 5]5.3.4.1 Kit of Parts Rules
<R36> So that every robot’s maximum power level is the same, the motors in the kit may not be modified in any
way, except as follows:
• The mounting brackets and/or output shaft/interface of the motors may be modified to facilitate the
physical connection of the motor to the robot and actuated part.
• The gearboxes for the Fisher-Price, and Globe motors are not considered “integral” and may be separated
• The electrical input leads on the motors may be trimmed to length as necessary.
Unread 26-01-2006, 15:35
I love you people. We need 450rpm for one application (prototyped with a cordless drill at 450rpm) and I was wondering if I was going to have to resort to a drive belt and pulleys. Stepping up a motor that had already been geared down seemed kind of dumb to me. Thanks!
Globe motor mounting DAN THE MAN Motors 15 14-02-2005 21:47
2 Globe Motors??? ChuckDickerson Motors 18 25-01-2005 15:53
Globe gear box Pat Roche Motors 9 25-05-2004 22:50
So you want to stall a Globe Motor... archiver 2000 1 24-06-2002 00:09
Globe Motors & other FIRST Suppliers at Design Show archiver 1999 2 23-06-2002 22:07
