Go to Post You must wear safety glasses at all times, so please bring them. - Don Wright [more]
Unread 26-01-2006, 15:51
cleonavicius cleonavicius is offline
AKA: Chris Leonavicius
FRC #0888
cleonavicius is an unknown quantity at this point
pic: Revised Ball Shooter
Unread 26-01-2006, 15:52
Re: pic: Revised Ball Shooter
Do you have trouble with that aggressive tread shredding Poof balls? That's what happened when we spun treaded wheels at 2,500 RPM...
Unread 26-01-2006, 16:07
Jon Jack's Avatar
Jon Jack Jon Jack is offline
VEX Robotics
no team (No Team)
Jon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond repute
Send a message via AIM to Jon Jack
With our two wheel shooter you could watch the foam fly off the ball as it left shooter.
Team 1538 / The Holy Cows, 2005-2016
Unread 26-01-2006, 19:41
coldabert's Avatar
coldabert coldabert is offline
The Dude
FRC #0888 (Robotiators)
coldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of light
Send a message via AIM to coldabert
When we tried another tire design without tread, it did not perform as well. However with this design, the balls are only momentarily contacting the tread and little shreading occurs.
Unread 27-01-2006, 02:36
Jeffdewber's Avatar
Jeffdewber Jeffdewber is offline
Mentor Now!
Jeffdewber is on a distinguished road
Yes I agree with professor coldabert as we call him. The shearding that occurs is very small nothing noticable.
Unread 27-01-2006, 18:33
thesse thesse is offline
Freelancer
FRC #0888
thesse can only hope to improve
Send a message via AIM to thesse
While I agree with the prof and Dewber that slight shredding occurs, if you mount the launcher to a table and shoot off five or six balls the table becomes covered with little chunks of foam.
-Theo
Unread 28-01-2006, 15:19
Jon K. Jon K. is offline
n.e.r.d #6
Jon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond repute
With all this talk of shredding balls, I would look into a redesign mostly because FIRST won't be to happy about that.
See the post here http://forums.usfirst.org/showthread...highlight=ball about ball damage.
Alumnus of FLL 2000 ~ Alumnus of FRC173 2002-2005 ~ Mentor of FRC173 2006-2007 ~ Mentor of FRC 3780 2014
FIRST Volunteer since 2003
Manufacturing Manager
AndyMark, Inc.
http://www.andymark.com
Unread 29-01-2006, 17:26
dtengineering's Avatar
AKA: Jason Brett
It IS possibile to build a one wheeled shooter that won't damage the balls and still achieve the 12m/s that is allowed (or close to it.)
We originally used the 9"x2" Skyway pneumatic wheel pictured at the beginning of this thread. It worked GREAT... but left, as mentioned, little pieces of foam and skin lying on the table where we had the mock-up mounted. We tried machining off the tread, but it still "visibly abraded the surface". So I posted the "Ball Damage - Follow Up" question mentioned above to the Q&A forum.
We have since revised our design, using two 8" Skyway kit wheels mounted a couple inches apart on the same shaft (it is still, essentially a single wheeled shooter), and adjusted for the decreased radius by bringing in the "wall" that compresses the ball by about an inch.
If you do the math... the 8" wheel is 20cm in diameter, or about 60cm in circumfurence. Spin it at 3000 rpm and you get 1,800 m/minute (30 m/s) linear velocity. Assume the ball will be travelling at 1/2 the linear velocity, and you will have all the speed that you are allowed... along with a comfortable margin to account for ball slippage, etc.
We've fired brand new poof balls from this set up dozens of times with NO visible damage. None.
FIRST does not mess around with its rules. If it is in the Q and A... it is in the rules. Shred balls at your own risk.
Jason
pic: CD 7 ball harvester BlazinFire47 Extra Discussion 21 14-05-2012 09:56
pic: Center Player Station and Ball Drop Wetzel Extra Discussion 2 08-01-2006 17:40
Knocking out Doubler Ball mightywombat Rules/Strategy 47 23-02-2004 15:18
pic: 2003 TechnoKat Ball Drive : Patent Pending CD47-Bot Robot Showcase 78 30-03-2003 16:27
pic: Ball Drive Close Up CD47-Bot Robot Showcase 17 04-03-2003 15:23
