Re: playstation controller conversion
I've never done it, or even played with a playstations output, but I have some idea of where you might start off. I believe that the controllers are both digital so you'd need to build a circuit that would allow you to interpret the signal, and then output that signal to either to a serial port or a usb port. Serial would probably be easier, but it'd still take a lot of work. You may be able to find instructions on converting a playstation controller to a computer gamepad online, which would make this much easier. After that you'll probably need to write a custom program to take the data and then edit it into a midi file. I have played with midi a little and the file format doesn't seem overly complex. If you look online you can find the file setup. I would think that unless there are easy instructions for using the controller w/ a pc, and using an input to come up w/ midi files this will be a lot of work, but it would also be pretty interesting, keep us posted on how it comes out.
this is related but sorry go off topic a little, are we allowed to use xbox/ps2 controllers for first?
This conversion is still not sanctioned as legal for First robots. There is a pending question on the Q&A watch for an answer.
that would be great if that can be figured out. perhaps one of the new wireless ps3 controllers would be good.
| White Paper Discuss: Playstation 2 Controller Adapter | jakep | Extra Discussion | 29 | 20-11-2006 21:18 |
| Mini-Me robot arm controller | Andrew Schuetze | Control System | 7 | 19-10-2005 11:07 |
| Connect Playstation Controller to PC USB. | kirov | Control System | 1 | 28-02-2005 08:24 |
| Help On Coding 2K1 Controller | GregTheGreat | Programming | 9 | 05-12-2003 18:35 |
| serious problem found - robot controller resets when jarred! | KenWittlief | Electrical | 23 | 19-03-2003 13:30 |
