Go to Post I've managed to convince my wife that Valentine's Day is February 24th. :) - dtengineering [more]
Unread 22-01-2006, 21:32
chrisinmd's Avatar
chrisinmd chrisinmd is offline
AKA: Chris Pickett
FRC #0888 (Robotiators)
chrisinmd is a jewel in the roughchrisinmd is a jewel in the roughchrisinmd is a jewel in the rough
Send a message via AIM to chrisinmd
Re: pic: 888 Ball Shooter Prototype
We thought the wheel size would take awhile to speed up. (Based on preliminary tests with softball pitching machine), but the large CIM gets to speed fairly quickly.
We took off the belt tension thing and mounted the CIM flat against the plywood.
-Chris
Unread 23-01-2006, 01:05
Andy B's Avatar
Andy B Andy B is offline
College Student, Mentor
FRC #1259 (Paradigm Shift)
Andy B will become famous soon enough
Send a message via AIM to Andy B
How did you mount it?
Did you drill and tap more holes?
Did you just use the mount that the tensioner lever was attached to?
Andy B: College Student, Mentor
Paradigm Shift, 1259 http://www.team1259.org
2004 Midwest Regional: Team Spirit Award Winner, Highest Seeded Rookie Team Award Winner, 4th Seed, 7-1-0 Record , Lost in Quarter Finals
2005 Midwest Regional: Imagery Award Winners, 16th Seed, 5-5-0 Record, Unpicked
2005 Championships, Newton Division: 5th seed, 6-1-0 Record, Advanced to semifinals
2006 Wisconsin Regional: Judges Award, 23th seed, 5-7-0 Record, Unpicked
2007 Wisconsin Regional: 33rd seed, 3-4-1 Record, Lost in Quarterfinals
Unread 25-01-2006, 23:13
cleonavicius cleonavicius is offline
AKA: Chris Leonavicius
FRC #0888
cleonavicius is an unknown quantity at this point
We removed the pulley and used the existing stud, as well as drilling and tapping a hole in the corner that sticks out of the face.
Unread 26-01-2006, 16:51
thesse thesse is offline
Freelancer
FRC #0888
thesse can only hope to improve
Send a message via AIM to thesse
Originally Posted by K.Shaw
doesn't it take the motor a little longer to speed up a wheel that size to max speed? once up to speed does the wheel slow down at all after a ball has been dropped in? are you able to shoot more than one ball a second and have them go the same height distance and land in about the same area? just a few things we ran into in our prototyping stages with a similar set up.
Yes it does take the motor longer to accelerate than with lighter wheels but that wheel seems to shoot much better than the others we tested. Also, the wheel does slow when you launch a ball, but quickly regains the lost speed and you are able to shoot a ball accurately about every 1.5 s.
-Theo
Team 358 Shooter Prototype Xero0ne Robot Showcase 14 20-01-2006 21:03
pic: cvt prototype CD47-Bot Robot Showcase 5 29-01-2004 01:10
pic: Swerve^2 Prototype CD47-Bot Robot Showcase 24 23-01-2004 12:11
pic: Team 857 Prototype Killough 2002 CD47-Bot Extra Discussion 19 13-10-2003 08:12
pic: Team 888 14" CD47-Bot Extra Discussion 2 16-03-2003 17:44
