Go to Post 1 alliance wins a given tournament but all teams teams have a chance to define, chart, and create their own success. - PayneTrain [more]
Unread 26-01-2006, 17:28
Best Available Data
FRC #1778 (Chill Out!)
Re: To ramp, or not to ramp?
Originally Posted by Eria4044
If getting up the ramp is as hard as everybody says it is, then the chance of all three robots getting on the ramp and staying there are slim. Having two alliance partners capable of staying on the ramp could be an enormous advantage, considering the increased points for doing so this year.
Why? Through my testing/visualization, if you have one robot on the flat part of the ramp, and one determined to get it off, you'll have one heck of a defensive battle, most likely with the robot who was there, still being on the ramp, although being in no position to be in front of the center goal. If you have two robots on the ramp, and any number of robots attempting to get them off, it'll be a waste of time, the two robots on top will remain on top, although spectacular play by the other alliance could change this. With 3 robots on the ramp, there's no point in trying to evict them. Reason being, the ramp is not very big from a turning standpoint. Assuming you drive straight up the ramp, you'll be hard pressed to turn, unless you can do so in within your starting drive base.
Holonomic drive and ramp robotaddict Technical Discussion 11 13-01-2006 16:57
Ramp and Platform model problem. Jay Trzaskos Inventor 1 08-01-2006 02:13
Ramp Riot 2004: Call for Comments OZ_341 Off-Season Events 4 28-11-2004 14:53
Pulling robot off ramp legal? archiver 2000 2 24-06-2002 00:14
Technical question about ramp balancing archiver 2001 5 23-06-2002 22:29
