Go to Post However, as a philosopher, while you need math, you can probably talk your way out of it. - sciguy125 [more]
Unread 26-01-2006, 19:20
sciencenerd's Avatar
sciencenerd sciencenerd is offline
ooh, what does this button do?
AKA: Kyle
FRC #1318 (the IRS (Issaquah Robotics Society))
sciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud of
Re: Green target has to "warm up"?
Originally Posted by Rick TYler
Each driving team consists of two DRIVERs, a COACH, a HUMAN PLAYER, and a LAMP WARMER.
The LAMP WARMER -- Each ALLIANCE shall provide one person to serve as LAMP WARMER, chosen from among the pre-college student members of the three teams in the ALLIANCE. Each LAMP WARMER shall be equipped with a 150-foot 3-conductor extension cord (at least 12AWG copper cable per conductor), a 120VAC 1000 watt heat gun, and a 10-foot Type IA step ladder. The extension cord and the heat gun must be unmodified and UL listed. The step ladder may be of any construction as long as it is certified as Type IA, and is equipped with rubber or other nonskid feet. The LAMP WARMER will climb the step ladder to prewarm the 2006 Vision Target. The LAMP WARMER may choose to remain on the ladder during the match, or climb down.
Heh, that's awsome! New custom title time!
So my question is, not being very familiar with the cold-cathodes, if you have it running for a while (long enough to warm up), turn it off, and then turn it on a couple minutes later, is it still warmed up? How long does the cool-down take? It seems that some people in this thread have been assuming it will stay warmed up, while others are assuming it won't. Can anyone enlighten me?
Oh, maybe I shouldn't have pushed that...
cmu cam woes... inability to target its objective Uberbots Programming 4 18-01-2006 18:41
LabVIEW - CMUcam finds target but cant track bear24rw Programming 6 13-01-2006 21:43
Purple Image after tryin to capture green. Code\\Pilot Programming 2 02-02-2005 16:55
Error - symbol 'e' has multiple definitions. HELLPPPPP BookerT Programming 2 24-01-2005 21:50
Reputation points SilverStar CD Forum Support 73 26-05-2004 02:14
