| View Poll Results: should bumpers be standard? | |||
| yes |
33 | 33.67% |
| no |
42 | 42.86% |
| standard except for length and size |
18 | 18.37% |
| bumpers? |
5 | 5.10% |
| Voters: 98. You may not vote on this poll | |||
bumper customization?
how does this allow for customization? i mean they kinda limit your ability to design. Last edited by gondorf : 26-01-2006 at 19:33. |
Re: bumper customization?
That's exactly the point. Basically they're giving you 15 lbs and three extra inches on each side. If you don't like the rules...you don't have to use them.
I think that they didn't want people designing "bumpers" with ball gathering mechanisms, or otherwise using the "bumpers can extend outside the robot boundaries" rule to an ungracious advantage.
You don't have to use the official FIRST spec bumpers. But...
If you do, you get the extra 15lbs. You also get the extra 3 inches or so. You can make your own bumper however you want but, You don't get the extra weight or size. You still can only contact other robots within the defined 'bumper' zone extending 8" from the floor. Also your bumpers cannot be more than 10 degrees from vertical. These last two restrictions are Rules, not Suggestions (like the bumper design). |
Anyone wonder how FIRST is even getting fifteen pounds out of the bumpers anyway? I mean, there is only a certain amount of perimeter on the robot, and only a certain way that you can build the bumpers. 15 pounds seems like a little much, unless you pour a little lead shot in with the noodles...
#7
It's a pity they specified plywood for the backing board. Our front and rear bumpers (more like collision protection bars) last year were 4/4 red oak. They had significant quantities of dings and scratches, but our robot was otherwise untouched. Plywood is pretty wimpy stuff by comparision. If you think of solid lumber as nature's own composite material, in plywood have the fibers are going the wrong way in an application like this. |
#8
The rules are a bit strict, as they do not allow for any customization to the bumpers, if the bumpers are to exceed the legal limit of the robot. But the bumpers are a huge advantage, seeing as they add width and weight over the legal limits without being illegal, bu tthat's only if you use the bumpers in the rules.
#9
Bumpers are a great idea. The problem is that the rules are very strict. With our kit frame and wheels and the lack of modifications allowed, we can't go up the ramp with bumpers. The modifications to the frame and wheels that would allow us to go up the ramp have undesirable effects. So at this time we most likely will not use bumpers. If First in an update allows modifications to the bumper height we would use bumpers. There are many problems with collisions involving bumpered and non-bumpered bots. This whole bumper issue needs rethinking by First going forward. Mandatory bumpers in a bumper zone with certain allowed design modifications would be a very very good thing.
#11
Well one thing my team usually does rather than bumpers is to design the robot so if someone tries anything, they'll be hurting thimselves more than the damage they wanted to do on us lol. See we cant get in trouble because we didn't try to hurt anyone, its just that someone tried us and hurt themselves in the process Bwahahahaha.
#12
well assuming that the rule posted previously^ is the only rule about bumpers, it suggests that you can put your bumpers on in sections. Since it doesn't say anything about all four sides, I think its a safe assumption that you can do bumpers on only two or three sides.
#14
I was just wondering if anyone has found a source for the specific pool noodles? I remember a thread where someone was having a hard time finding the noodles.
Thanks, Kirk |
#15
we were able to get our bumpers one ebay pretty cheap just look around
| Confessions of a serial bumper... | Joe Johnson | Car Nack's Corner | 3 | 13-01-2006 15:31 |
| Bumper modification | Doogie | Technical Discussion | 4 | 11-01-2006 22:37 |
| Bumper sensors | jeffmorris | FIRST Tech Challenge | 1 | 02-10-2005 16:20 |
| Bumper Classification | Sachiel7 | Rules/Strategy | 5 | 30-01-2005 18:43 |
