Go to Post Backwards PWMs happen to the best of us. - Woolly [more]
Unread 26-01-2006, 20:22
RedOctober RedOctober is offline
FRC #0291
RedOctober will become famous soon enoughRedOctober will become famous soon enough
Help with Gear Tooth Sensor
Hey, can i have some information for the gear tooth sensor other than the data sheets. I have read them and I still do not understand what kind of outputs that it returns to the user. Is there also a way to view the output from it in real-time? If it is in the NI Labview software, where is it? I'd appreciate any help.
Unread 27-01-2006, 09:33
Re: Help with Gear Tooth Sensor
The gear tooth sensor provides a short high-going pulse every time a metal gear tooth passes the face of the sensor. It requires 12 volt power, and is intended to be connected to one of the interrupt-capable digital inputs on the Robot Controller.
Software on the RC is used to count the pulses from the sensor. (I believe there's a hardware counter as well, but I've never used it.)
You can view its output directly with an oscilloscope.
Unread 27-01-2006, 17:30
zachriggle zachriggle is offline
FRC #1940
zachriggle is infamous around these parts
So the GTS doesn't have to have a gear-tooth actually TOUCH the PCB, but just pass by it? How does that work!?!?
Unread 27-01-2006, 18:38
Here is information on a similar device provided in the Kit of Parts last year.
Gear Tooth Sensor Talha Electrical 1 23-01-2006 21:29
gear tooth sensor connecting problem nirty Electrical 2 23-01-2006 12:17
Gear Tooth Sensor AMIRAM Electrical 2 22-01-2006 04:09
Gear Tooth Sensor Question (InsrtNameHere) Electrical 2 20-01-2006 02:19
Gear tooth sensor vs. Optical Encoders Avarik Programming 7 17-01-2006 10:18
