Let's find ourselves a trailer and get hitched!
Unread 26-01-2006, 20:46
amateurrobotguy's Avatar
amateurrobotguy amateurrobotguy is offline
Lead Programmer/Senior Engineer
amateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these parts
Re: CMUcam2 code for EDU-RC?
Can't you just get rid of the converter chip altogether when using the edu-rc and just run a pwm cable from the ttl on the camera board to the ttl on the edu-rc since it has the 3 pin ttl on it and the camera board has 3 as well?
I quit FRC over 2 years ago (more if you're reading this past 2010).
2006 CMUcam2 Code Kevin Watson Programming 81 10-02-2007 20:17
CMUCam2 code (FRC and EDU?) Amber Programming 0 15-02-2005 22:23
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
