Hopper?
I was just wondering how many teams are going to expand out to the 5 sq ft max for a hopper to human load. A couple of mentors from our team feel it is essential to have a hopper instead of picking up balls off the floor. Any suggestions?
Re: Hopper?
Hoppers are definitially a good wasy to store, and possibly load balls this year.
However, have you thought of how many balls you'd acutally be able to hold having that big a hopper? My team has found that there is more than enough room in the original robot footprint to hold a fair amount of balls. If you built a hopper just within the original footprint (max) size, you could hold over 186 balls. Remember that there are only 80 in each match, and your robot only needs to be able to hold 10 for autonomous. So, unless youre planning on hoarding all 80 balls, you probably don't need to extend much, if at all. edit: a few more thoughts... You aren't limited to not getting floor balls w/ a hopper. There are easy ways to accept both HP balls and floor balls in the same storage space. Also, back to the idea of expanding. Note that in order to expand, your robot will need an extra mechanism to expand once the match begins. It doesn't nessicarily have to be powered, but it will mean a large (possibly) mechanism, more weight, etc. My team has built our "small" hopper. It's not very big...I think its around 18"x24"x20", and I think it'll hold 15-20 balls. That should be plenty for us. Consider these kind of things when designing your own. Last edited by Sachiel7 : 26-01-2006 at 21:31. |
Re: Hopper?
thats what we claimed, how many balls do you need to carry around during a 40 sec match? not 80.
Re: Hopper?
Re: Hopper?
Re: Hopper?
Well, don't forget the tournament ranking/scoring. Even if you win, you're walking away w/ your opponents unpenalized score.
Yes, I think holding alot of balls may be advantagous, but my question is, what are you doing with the balls? Shooting them into the center goal? If so, you also want to take into account your scoring speed. If you can only score 10 balls in 40 sec, there's not a big point to holding 20 balls in the last 40 seconds unless youre really desperate to keep your opponent from scoring. Just my opinion... |
#7
Re: Hopper?
but truely how many balls do you need to hold at a time. i doubt you can hold 80 balls and still have a relaible shooter while remaining in the size contraints.
#8
Re: Hopper?
I believe the primary advantage of being able to expand your hopper is that it makes it much easier for your Human Player to toss balls in from far away.
#9
Re: Hopper?
i think the most effective mode will be to pick up from the floor yet have the ability to hold about 10 balls. any other beliefs?
#10
Re: Hopper?
Re: Hopper?
Re: Hopper?
when on defense you have two robots near the human player, so they are more easily loaded then the BackBot which is behind the mid-field line... the bigger the target the easier it will be for the HP to toss a ball into the robot. If your robot is easy to load all three HP in your alliance can be loading it up as a team ! --Mike |
#13
Re: Hopper?
ok i understand it would be easier. now would you change you entire design after is 1/2 built just becuase these mentors now want a hopper?
#14
Re: Hopper?
In my opinion simply throwing the balls near your robot should be good enough. A bigger hopper will mean you can throw balls in easier, but throwing them near your robot on the ground and quickly picking them up is just as effective, plus it gives you the bonus of being able to get balls when your human players miss shots (and you can steal opponent's balls). If you do go for human player loading, it would be wise to expand the hopper though (you don't necessarily have to expand the whole thing even, just the top so the balls will roll in). |
#15
Re: Hopper?
In this case, if you want a hopper, just leave the top open. If you have time/weight/space on your current design, then add something to help snare HP throws. |
| were there robot related injuries on your team? | Will Hanashiro | General Forum | 233 | 08-03-2009 15:42 |
| Hopper Question | pacoliketaco | Technical Discussion | 5 | 21-01-2006 23:15 |
| FRC 2002 Very Fast Ball Collector | groves | Technical Discussion | 13 | 12-01-2006 15:54 |
| hopper or magazine | ewankoff | Technical Discussion | 9 | 12-01-2006 01:08 |
| Kudos to Team 95, Lebanon Robotics | archiver | 2000 | 0 | 23-06-2002 22:16 |
