Go to Post Andymark has everything! - nighterfighter [more]
Unread 26-01-2006, 21:24
Jared Russell's Avatar
Taking a year (mostly) off
Re: Gyro not accurate - Problem
Originally Posted by Rick TYler
This is a really good (hint) suggestion. Remember that you have power to your robot when you set it up for autonomous. There is no reason to wait for the referee to turn on your motor controls to "fire up" and set the "not moving" value of the gyroscope. (Thanks to Team Titan Robotics, FRC 492, for teaching us about this in the off-season.)
Just be careful not to move your robot around the starting zone once you've powered up if this is the case
atan Problem - Need Help the_undefined Programming 0 18-02-2005 11:16
Physics Problem Venkatesh Math and Science 13 30-11-2004 20:30
No Signal From Gyro colt527 Programming 12 19-10-2004 07:30
Ok one problem cantwell03 Programming 3 13-02-2003 07:28
Have YOU used the gyro chip? FotoPlasma Technical Discussion 10 31-01-2002 13:26
