Go to Post One of my early mentors gave me wise words -- when designing a system to compile & analyze information, your first design choice should always include consideration of a stack of 3x5 file cards. - Jaxom [more]
Unread 26-01-2006, 14:32
jpyro jpyro is offline
AKA: john edwards
FRC #1108 (Panthers Robotics)
jpyro is an unknown quantity at this point
playstation controller conversion
If any one knows how to convert a Playstation 2 or Xbox controller to midi? this is not for robots its for my own free time. Or what time i have in the shop doing nothing. HAHA
Unread 26-01-2006, 16:25
patTeam241 patTeam241 is offline
College Student
AKA: Pat Cleary
patTeam241 will become famous soon enoughpatTeam241 will become famous soon enough
Send a message via AIM to patTeam241
Re: playstation controller conversion
I've never done it, or even played with a playstations output, but I have some idea of where you might start off. I believe that the controllers are both digital so you'd need to build a circuit that would allow you to interpret the signal, and then output that signal to either to a serial port or a usb port. Serial would probably be easier, but it'd still take a lot of work. You may be able to find instructions on converting a playstation controller to a computer gamepad online, which would make this much easier. After that you'll probably need to write a custom program to take the data and then edit it into a midi file. I have played with midi a little and the file format doesn't seem overly complex. If you look online you can find the file setup. I would think that unless there are easy instructions for using the controller w/ a pc, and using an input to come up w/ midi files this will be a lot of work, but it would also be pretty interesting, keep us posted on how it comes out.
Sometimes mentor for 241: Pinkerton Academy. At Northeastern University in Boston.
AOL SN: Splinztz
"Make no little plans; they have no magic to stir men's blood" - Daniel Burnham
Unread 26-01-2006, 16:33
MrBamboo MrBamboo is offline
Lead Designer of #1888 (Plano West)
AKA: Fei
FRC #1888 (Sigma F)
MrBamboo is an unknown quantity at this point
this is related but sorry go off topic a little, are we allowed to use xbox/ps2 controllers for first?
Unread 26-01-2006, 16:37
Francis-134's Avatar
Francis-134 Francis-134 is offline
Lifer
FRC #0190 (Gompei and the Herd)
Francis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond repute
As long as the controller does not have any source of power outside of the OI, then it is legal. If you give a search, you can find a thread about a team that was able to make a DualShock 2 contoler work with the OI.
Email | Twitter | Facebook | YouTube | Twitch
iTunes Podcast | Snapchat
A proud alumnus of teams 134 and 40 || Mentor of Team 190 || Director of Fun for BattleCry@WPI
Unread 27-01-2006, 07:23
This conversion is still not sanctioned as legal for First robots. There is a pending question on the Q&A watch for an answer.
Unread 27-01-2006, 12:50
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
And the answer is..... (let me put the question FIRST so we are all on the same page...)
Rule R78 states: "All equipment connected to the Joystick Ports of the IFI Operator Interface must be powered solely through the power available through the port." and "Portable computing devices may not be connected to Joystick input ports on the Operator Interface."
Regarding the definition of "portable computing device", would a custom circuit that used a microcontroller to convert signals from a newer, digital joystick to the analog format needed by the Operator Interface be considered legal as long as it was powered by the joystick port?
And now the answer is...
Yes, it is legal.
Wheew... we collected alot of cans to have the 6 circuit boards professionally made... and it drive SO much nicer than the old controllers. This comming from a guy who grew up on the old style Atari controllers.
Brian Graham
Unread 31-01-2006, 17:52
tyklink's Avatar
tyklink tyklink is offline
AKA: Taylor Kuizenga
FRC #0079 (The Navigators)
tyklink is an unknown quantity at this point
that would be great if that can be figured out. perhaps one of the new wireless ps3 controllers would be good.
White Paper Discuss: Playstation 2 Controller Adapter jakep Extra Discussion 29 20-11-2006 21:18
Mini-Me robot arm controller Andrew Schuetze Control System 7 19-10-2005 11:07
Connect Playstation Controller to PC USB. kirov Control System 1 28-02-2005 08:24
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
