Go to Post Teach them to fish by catching the first fish for them. (Give them the answer, but also give them how you came to that conclusion) - David V [more]
Unread 26-01-2006, 15:27
Chuck Merja Chuck Merja is offline
Chuck Merja is an unknown quantity at this point
chronograph
I've been reading about some fast flying balls and was just thinking that we shoulda at least been supplied a schematic for a chronograph, so we don't have a bunch of overclocked robots end up at regionals.
Anybody already beat me to this and have a chono design they'd like to share?
Unread 27-01-2006, 10:19
ldeffenb ldeffenb is offline
AKA: Lynn Deffenbaugh (Mr)
None #0386 (Team Voltage 386)
ldeffenb has a spectacular aura aboutldeffenb has a spectacular aura aboutldeffenb has a spectacular aura about
Send a message via ICQ to ldeffenb Send a message via AIM to ldeffenb Send a message via Yahoo to ldeffenb
Re: chronograph
Quiz: How long does it take for a ball to move its own diameter at the maximum muzzle velocity?
My calculation shows about 14msec, any others?
Unread 27-01-2006, 10:45
Re: chronograph
Closer to 15.
12 meters per second.
1000 milliseconds per second.
39.37 inches per meter.
7 inches per ball diameter.
1 sec   1000 ms     1 m      7 in   14.82 ms
----- x ------- x -------- x ---- = --------
 12 m    1 sec    39.37 in   diam   diameter
Unread 27-01-2006, 22:39
zachriggle zachriggle is offline
FRC #1940
zachriggle is infamous around these parts
Re: chronograph
Your best bet would be to locate a local paintball shop. At the very least, you could bring your robot to their location, and use their chrono to measure ball speed (in feet per second). One of my friends happens to be a referee for paintball, so we're actually going to bring one of their chronos to the match. The chronos are highly accurate (seeing 1cm diameter balls at 180fps is no easy task), and work from a good distance, too. We're bringing him with us to stand on the sidelines and track opponent ball speed... so that we can notify the referees of any violations that we notice (not that it'll have any official bearing, but they may take the robot to the side to do tests, and tell the team to throttle it back).
Unread 27-01-2006, 22:57
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
Re: chronograph
I hope that will not be necessary, I am confident that FIRST will have some sort of testing system in place at the regionals. I'm not sure that the refs will respond positively to a team coming up to them with a radar gun saying that an opposing robot was shooting the ball too fast.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 28-01-2006, 05:43
Kirk Kirk is offline
FRC #0254
Kirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud of
Send a message via AIM to Kirk
Re: chronograph
The only problem is that paintball chronos only read down to about 100 fps. I have one of my own and tried to use it and it just gives me an error. I think teams are going to have a hard time finding a chrono that will go that slow.
Kirk
Unread 28-01-2006, 11:38
Re: chronograph
Well, I was actually thinking of an emitter/detector pair close to muzzle, that would capture velocity info. The gun chronos I'm familiar with use leading edge (of bullet) detection and known distance between detectors to calc velocity. But maybe we could use one e/d pair and assume a constant (length) of our poofs. May be OK - depending upon the poof deformation/deformation variation.
Unread 30-01-2006, 15:17
Dick Linn's Avatar
no team (Synergy)
Re: chronograph
You might adapt one of the many low-cost pinewood derby timing circuits to measure ball speed. Some display time and you could use a two lane timer and use the differential time to calculate velocity. Some of these circuits are very simple, and use a PC parallel port & a program to do the hard work.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
