Go to Post I...want...to...go...to...Champs. REALLY REALLY BADLY. - CalTran [more]
Unread 22-01-2006, 07:13
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Accelerometer integration
Hey,
Despite this thread, I want to use accelerometers for a bit of navigation this year.
In the attached excel spreadsheet, you can see that using the angles 0degrees 45degrees and 90degrees, I have found that the relation between the real acceleration and the output value is non linear and appears to be something like:
y=(a^3)/12+500
where a is the real acceleration and y is the sensor value.
My questions:
1)How can I convert this to a more linear connection? (do i need to?)
2)How do I integrate the values over time to get speed and more importantly distance?
Thanks!
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 27-01-2006, 02:44
doubleslash's Avatar
doubleslash doubleslash is offline
driven
AKA: Justin Huang
FRC #0649 (Saratoga Robotics)
doubleslash is an unknown quantity at this point
Send a message via AIM to doubleslash
Re: Accelerometer integration
Integrating the acceleration is pretty straightforward; dimensional analysis tells you that all you need to do is multiply your acceleration by your time element (if you're in user_routines, that would be 0.0262 seconds) to get velocity, and multiply your velocity by your time element to get your distance.
I would be careful with that, though, I've been having quite a time trying to get the acceleration to integrate accurately.
I, I'm allergic to bee stings. They cause me to uh, die.
Unread 27-01-2006, 09:48
to get the real equation you have to remember that acceleration is a vector - it has magnitude and direction
when the bot is not moving the magnitude is 1g, and its pointing straight down
when the bot is accelerating forward at 1g on a level surface, the magnitude the sensor will read is (1^2 + 1^2)^ 0.5 = SQRT(2) and the direction will be 45° forward from -Z.
so the forward magnitude of the robots total acceleration vector should always be = SQRT(sensor^2 - 1^2) [units = g's]. You must keep track of the direction through the SQ and SQRT calculations.
note that 1^2 assumes the sensor reading has been scaled so that 9.8M/S^ = 1g. also, if the robot is not on a level surface you must know the angle that it is tilting to separate out gravity and motor acceleration.
Unread 27-01-2006, 11:43
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
I may have gotten things all wrong but I was under the impression that the accelerometer tells you the magnitude of acceleration on a given axis.
so if you know how you mounted the accelerometer you would know the acceleration direction relative to the robot (though you would miss any part of the acceleartion perpendicular to the axis that the accelerometer was measuring unless you had two gyros or a dual-axis accelerometer)
-Leav
-Paraphrasing JFK
Unread 27-01-2006, 11:56
Leav,
you are correct - if the accelerometer is positioned with its axis horizontal, then gravity will not affect the reading, unless the robot tilts (climbs a ramp).
For some reason I had tilt-sensing on my mind and got the two applications mixed together.
I dont understand your original equation at all: a^3 ?! Which accelerometer are you using, I will look up the data sheet and see if I can make sense of this.
Accelerometer Timer Question psquared Programming 3 12-02-2005 01:34
URGENT! We need help with the accelerometer lkdjm Electrical 5 11-02-2005 16:42
Accelerometer Wiring/Input DAN THE MAN Control System 1 06-02-2005 20:02
Accelerometer vs Gear Tooth Sensors zdeswarte Electrical 4 22-01-2005 15:35
Example accelerometer code released. Kevin Watson Programming 0 20-01-2005 03:45
