Go to Post I said it was called FIRST Robotics and the coolest thing I'd seen that day was a 150lb robot balance with another one on a teeter-tooter and and then score basketballs from 30 feet away. - Siri [more]
Unread 27-01-2006, 14:53
Warren Boudreau Warren Boudreau is offline
FRC #0180 (Team SPAM)
Warren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond repute
Re: Working with Lexan
We've used Lexan for just about everything at one time or another. The best way for cutting/drilling holes that we've found is to use WD-40 as a lubricant.
Have someone spray it onto the bit while you are cutting/drilling.
You have to keep the bit cool. Once the Lexan starts to melt, it grabs the drill right out of your hands. Been there, done that. Ouch.
Also, If you have any plans on screwing into the stuff, we've found that drywall screws work very well. You have to drill a pilot hole and use lithium grease (or some other lubricant) on the screws. If you are using a drill to drive the screws, be sure to set the torque limit down to about 6. You will shear the screws and they are not fun to get out after that.
Warren B
Pool Noodles. They're not just for bumpers anymore.
Sources for Delrin and Lexan stock sanddrag Technical Discussion 3 04-12-2005 00:25
Who is working on their team site over the summer? Timothy D. Ginn Website Design/Showcase 15 07-06-2005 18:47
IR Beacon/reciever not working... still... Ferazel2001 Programming 23 04-02-2004 23:30
I'm working :) Jack FIRST Scouting Network 2 03-01-2004 01:26
Whose working this summer? Frank(Aflak) Chit-Chat 20 28-05-2003 11:35
