Go to Post Actually, I think the standard Klingon warning label ought to be sufficient: 'yIQIpQo' (don't be stupid) - Alan Anderson [more]
Unread 27-01-2006, 02:09
Joe Hershberger Joe Hershberger is offline
National Instruments
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
Why use the RC to control Pan/Tilt
Kevin,
I'm curious why you chose to control the Pan / Tilt for the camera with the RC instead of using the control built into the camera. What advantage or additional capability do you gain by doing that?
Thanks,
-Joe
Unread 27-01-2006, 02:15
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Re: Why use the RC to control Pan/Tilt
Originally Posted by Joe Hershberger
Kevin,
Thanks,
-Joe
It takes longer for the CMUCam servo controller to respond (up to half a second).
This practically eliminates any kind of PI control except for the on-board one, which is also slow.
Just my $0.02
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 27-01-2006, 03:56
scitobor 617's Avatar
scitobor 617 scitobor 617 is offline
More nerd than you can handle!
AKA: Alan Meekins
FRC #0617 (HSHS 617 "DUKE")
scitobor 617 will become famous soon enoughscitobor 617 will become famous soon enough
Send a message via AIM to scitobor 617
By using the RC it makes it very easy to tweak or completely change the search algorithm to find the target quickly.
Beta testers needed!
http://www.nullagent.no-ip.com
Your kidding, there are other operating systems besides Linux?!
Unread 27-01-2006, 13:57
Kevin Watson's Avatar
La Cañada High School
FRC #2429
Kevin,
Thanks,
-Joe
The major reason I spend hundreds of hours a years writing and supporting code on my own dime is because I hope a few HS students might learn something new from reading my code. If they learn something cool, maybe they'll take the time to really dive into the code and improve upon it (setting the hook, so to speak). If I just took the lazy route and used the camera to do the tracking, the kids wouldn't have some code that they could use as a starting point and discussions like this one wouldn't have taken place.
Perhaps I should ask you what disadvantage is there to providing more information & learning opportunity?
-Kevin
Kevin Watson
http://kevin.org
Unread 27-01-2006, 15:06
Originally Posted by Kevin Watson
...If I just took the lazy route and used the camera to do the tracking,...
I think Joe was asking why you didn't use the camera's servo outputs, not why you didn't use the camera's automatic tracking firmware.
Your provided code has a small disadvantage: the camera cannot track while the robot is disabled. That keeps robots from finding the goal target light in advance of entering autonomous operation. Using the CMUCam "SV" command instead of the RC pwm output would let robots get a lock before they are enabled to move. We're working on modifying the camera tracking code to do it that way, and I am grateful for the well-documented code.
Unread 27-01-2006, 15:27
FRC #2429
If the green light is within the camera's field of view when autonomous period starts, the software will converge on a solution in much less time than it'll take to fire-up motors.
Because the software is modular, I suspect that it would be very easy to let the camera do the tracking and/or control the servos.
-Kevin
Kevin Watson
http://kevin.org
Unread 28-01-2006, 05:06
AKA: jhersh
-Kevin
Have a bad day? Maybe a little too defensive. Not everyone has an agenda or is out to get you.
I had an honest question about the reason behind your design decision. It wasn't laced with criticism, didn't imply that you were wrong or foolish for doing it that way, and didn't even suggest a preference. Given the two options, you chose one over the other.
so....
I hope a few HS students might learn something new from reading my code... [I took that approach] to provide more information & learning opportunity.
Thanks,
-Joe
Unread 28-01-2006, 06:18
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Kevin,
Thanks,
-Joe
Another advantage is that you can control the camera a different way, say mount it on top of a rotating turret, which eliminates the need for another way to pan.
Unread 28-01-2006, 13:27
FRC #2429
... snip ...
Thanks,
-Joe
*sigh* I guess this is some kind of amateurish attempt to provoke a negative response from me. I haven't a clue why you're being so disingenuous or what your agenda is, but you should be ashamed of yourself for pulling something like this in a public forum where we're attempting to promote engineering and the sciences as a career choice for adults.
-Kevin
Kevin Watson
http://kevin.org
Unread 28-01-2007, 01:54
htwiz2002's Avatar
htwiz2002 htwiz2002 is offline
Htwizard
AKA: Anthony Takata Bawahawba
#1290
htwiz2002 will become famous soon enough
Question Re: Why use the RC to control Pan/Tilt
I have a small question (which is probably answered somewhere obvious) But how do I go about setting the pwm values on the camera?
I have it hooked up properly (based on last year's camera, which worked apparently) however I don't know how to get the camera to output values to them.
I can verify the pwms are plugged in correctly because upon initialization and (possible) activation the camera ZIPP!s into position (and stays there no matter what i set pwm01 or pwm02, or PAN or TILT).
What do I do to set this?
Edit:
I just read Rule <R28> revision #2 which stated that i could not use the 2006 camera! Oops . Well, I guess i need to get longer pwm cables! . Oh well, just go with the flow...
TsAuKpAeTrA (Anthony)
Last edited by htwiz2002 : 28-01-2007 at 02:33. Reason: Updated infor changed question
Unread 28-01-2007, 09:38
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
It is not legal to control servos with the camera's PWM output this year anyway:
http://forums.usfirst.org/showthread.php?t=1747
Unread 28-01-2007, 15:55
FRC #2429
Originally Posted by jgannon View Post
But c'mon... give the kid a break.
1) He's an engineer, not a kid.
2) My exchange with Joe is a year old. I'm going to have a talk with some CMU professors I know, because they clearly aren't piling on enough work if you have this much free time on your hands .
3) In hindsight I can certainly see why you might think I was quick to jump on Joe, but you're not aware of the other messages that preceeded my exchange with him that convinced me he was playing the alpha-geek game. As there are few things in life I dislike more than getting pulled into an alpha-geek game, I quickly made it undesirable for Joe to continue so that I could get back to more enjoyable endeavors. One of the best methods to quickly stop such activity is to shine a light on it and call it what it is: bad behavior. Though my timing was off, this is exactly what I did, and it worked. Unfortunatly, because I was too quick to fix the problem, it made me look like I'm nuts, which may or not be true .
4) I think I have a few good reasons for choosing to use the RC PWM outputs rather than the CMUcam2 outputs. I've noticed quite a few questions about the subject this year, so I think I'll give the quick answer here and then follow-up with a more detailed answer in the FAQ if time allows.
Firstly, I wanted teams to have all the source code in their hands so that they could have something to improve upon should they desire, including the searching/tracking code.
Secondly, it made more sense to me to have the camera send t-packets as fast as it could (~11 Hz) by using the Track Color command. Otherwise I would need to used polled mode, which is much less efficient and possibly risky because I'd need to asynchronously cross clock domains twice, instead of once.
Third, I had a hard time getting the camera to initialize correctly. It would lock-up and stop communicating if I didn't send it commands with perfect timing and in just the right order. The experience dealing with the fragile communication interface made me a little apprehensive about using polled mode, and made the use of the streaming Track Color command that more attractive. The last thing I wanted was to be mentioned in the same sentence as the FRC scoring software, so I took the more conservative approach.
-Kevin
Kevin Watson
http://kevin.org
Unread 28-01-2007, 16:08
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Okay, now I look like I'm nuts... I didn't notice that somebody else had brought this thread back from the dead. I understand the "alpha geek game" you're talking about, and I sympathize. In any case, I take it back. And yes, I'll be getting back to my work now (CMU gives me plenty without your help, thanks). I'm just glad to see that you haven't completely lost it.
Also, thanks for the explanation of why you're doing it the way you are. I'm currently trying to cobble together some CMUCam stuff with your EDU serial ports code for a different project, and now I've got some things to think about.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 30-01-2007, 22:26
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Ouch, that hits close to homework. Some ideas that seem really cool early on should just be avoided, the problem is that the point at which you realize you should have quit sometimes comes right after you've finished. I sometimes wish I was one of those who doesn't know what you're talking about, as my ears are still ringing from it and I didn't have a part in it!
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Unread 30-01-2007, 22:59
FRC #2429
-Danny
Whoops, no, I wasn't referring to what you think I was referring to! I was thinking about the organization that had overall cognizance of the scoring system for the last few years.
-Kevin
Kevin Watson
http://kevin.org
Concept of PID explained ConKbot of Doom Technical Discussion 11 27-01-2008 00:11
Pre-manufactured control box for FIRST Ben.V.293 Technical Discussion 19 22-08-2005 12:53
2005 RadioShack Innovation In Control Award--What Won? Billfred Control System 8 12-06-2005 01:51
2005 RadioShack® Innovation in Control Award! dez250 General Forum 10 10-03-2005 21:29
What do you wish you knew about the new control system? Joe Ross Control System 2 09-01-2004 21:47
