Hi,
I'm a little concerned about my gyro sensor... I've never noticed that it works with it's pic in a ultra-super-high temperature... Does your gyro works in high temperature too? Is it normal?? Or there's an evil short-circuit that i can't see?? thanks, Giovane |
Re: Doubts about Gyro Temp
How are you determining that your gyro is getting hot?
If you're using the temperature output, make sure you are converting the output correctly. Room temperature should be ~2.5V, which corresponds to 298 degrees K, or 25 degrees C. A difference of 8.4mV will equal +/- 1 degree K (or C). |
| Gyroscope Code | Kevin Watson | Programming | 65 | 01-03-2008 23:46 |
| Updated: Example Gyro Interface Code | Kevin Watson | Programming | 2 | 28-03-2005 04:36 |
| Example gyro code released. | Kevin Watson | Programming | 60 | 17-03-2005 18:32 |
| arm-limitting gyro PD loop producing some strange results | ZZII 527 | Programming | 8 | 16-02-2005 02:30 |
| Gyro Troubles | SteveO | Programming | 13 | 30-01-2005 16:46 |
