Go to Post Robotics for me though really is hard to beat. Though tiring and exhausting, the memories you build are priceless. - ShadowKnight [more]
Unread 15-01-2006, 03:11
Kevin Watson's Avatar
La Caņada High School
FRC #2429
CMUcam2 Serial Port Diagnostics
For those that might be interested, I've created a utility application that can be used to verify the proper operation of your robot controller's serial ports, CMUcam2, TTL to RS232 conversion circuit, and cables. The code can be found here: http://kevin.org/frc. Here's the readme file:
FRC robot controller serial port diagnostics is a utility to
test the serial ports of your robot controller. It simply
takes all data sent to the programming port and sends it back
out the TTL-level serial port and conversely takes all data
sent to the TTL-level serial port and sends it back out the
programming port. Two important tests can be performed with
this software:
1) First is a loop-back test, which tests the the transmit
and receive circuits of both serial ports at the same time.
To perform this test, attach the programming cable between
your computer and robot controller and using the IFI loader,
upload the serial_port_diagnostics.hex file included with
this project. Once you've done that and see the text "Serial
Port Diagnostics Running..." on your terminal window, remove
power from your robot controller and install the IFI TTL to
RS232 interface board and PWM cable that came with your
CMUcam2. Now short the red and white pins together with a
small piece of wire or a 0.1" jumper block. Now apply power
to your robot controller and once the "Serial Port Diagnostics
Running..." text appears, type some characters into the "To
Port ->" box under the terminal window and press the enter
key. Did the same characters appear on your terminal window?
If not, make sure everything is connected properly and try the
test again. If the correct characters did appear, you know that
your serial ports, TTL to RS232 board and cable are working.
2) The second test involves plugging the PWM cable back into
your CMUcam2 and applying power to the robot controller and
CMUcam2. Once the "Serial Port Diagnostics Running..." text
appears, Click within the "To Port ->" window and press the
enter key a few times. Did the text "ACK" or "NCK" appear on
your terminal window? If not, it means that your camera is
either misconfigured (e.g., wrong baud rate) or defective.
If you got at least one "ACK" back from the camera, you know
that you can successfully communicate with your CMUcam2.
-Kevin
Kevin Watson
http://kevin.org
Unread 16-01-2006, 09:44
railerobotics's Avatar
railerobotics railerobotics is offline
FRC #0935
railerobotics will become famous soon enough
Re: CMUcam2 Serial Port Diagnostics
I did your first test but it did not display Serial
Port Diagnostics Running in the terminal.
I have done your second test and it still didn't display Serial
I even tried both the tests with the camera from last year.
Unread 16-01-2006, 13:02
FRC #2429
Did you try hitting the reset button?
-Kevin
Kevin Watson
http://kevin.org
Unread 16-01-2006, 13:21
FRC #0935
Yes mulitple times
Unread 16-01-2006, 13:59
FRC #2429
Yes mulitple times
I'm pretty clueless here. You're able to load the camera code, but it reports, via serial port one, that it can't find the camera on serial port two. Now, not even serial port one works. You've got solid green lights on the robot controller and the tethered operator interface, right? Are you loading the code using a real serial port (i.e., not a USB port with a serial converter)? You're using IFI Loader 1.0.12?
-Kevin
Kevin Watson
http://kevin.org
Unread 16-01-2006, 14:02
FRC #0935
I am not using USB port with a serial converter but what do you mean by a tethered operator interface. My serial cable is plugged into the program port of the robot controller if that's what you mean.
Unread 16-01-2006, 14:13
FRC #2429
...but what do you mean by a tethered operator interface.
You must have an operator interface connected to the robot controller before the robot controller will run your code.
-Kevin
Kevin Watson
http://kevin.org
Unread 16-01-2006, 14:14
FRC #0935
I finally got someting in the terminal window. It gives and bunch of options for changing color values. What do I do know that camera doesn't track. And it never displays searching. But sometimes it doesn't display anything at all. I re downloaded the code but this time nothing was in the terminal window
Unread 16-01-2006, 14:48
FRC #2429
Do you have the operator interface tethered, via the red cable, to the robot controller?
-Kevin
Kevin Watson
http://kevin.org
Unread 16-01-2006, 15:00
FRC #0935
Yes, we do. By typing com1 at the bottom of the terminal window we get color values but I don't know what to do next.
Unread 16-01-2006, 15:29
FRC #2429
Actually, all you need to do is type the letter 'c' to bring up the camera menu. Typing the letter 't' will bring up the tracking menu. This is all documented in the camera software.
I'm not sure if I asked this before, but can you load the IFI default code? Does it work?
You need to re-load the serial_port_diagnostics.hex file and hit the reset button. Then follow the included instructions to make sure you can communicate with the camera. If you don't get the "Serial Port Diagnostics Running..." message, I don't have a clue what might be happening here.
-Kevin
Kevin Watson
http://kevin.org
Unread 16-01-2006, 15:37
FRC #0935
I loaded the serial port diagnostics but still don't see the Serial Port Diagnostics Running... message
Also when I load the camera code, I can change values but the terminal never says searching.
Unread 27-01-2006, 17:31
Vashts6583's Avatar
Vashts6583 Vashts6583 is offline
The sleepless
AKA: Rob Metzger
FRC #0007 (Team 007)
Vashts6583 is a name known to allVashts6583 is a name known to allVashts6583 is a name known to allVashts6583 is a name known to allVashts6583 is a name known to allVashts6583 is a name known to all
Send a message via ICQ to Vashts6583 Send a message via AIM to Vashts6583 Send a message via MSN to Vashts6583 Send a message via Yahoo to Vashts6583
Exclamation Re: CMUcam2 Serial Port Diagnostics
MP2COD 3.90, COFF to COD File Converter
Copyright (c) 2004 Microchip Technology Inc.
Error - Source file 'C:\Robotics\2006\Code06\frc_serial_port_diagnosti cs\ifi_startup.c' name exceeds file format maximum of 62 characters.
Errors : 1
2005: Software Assistant
2006: Software Head
2007: President/Driver/Software Head/Temporary Safety Captain
//2005: Chesapeake Regional - Finalist
Life is what you do outside of FIRST. No wonder it's so short.
Unread 18-02-2006, 15:05
lil_longo's Avatar
lil_longo lil_longo is offline
AKA: Brian
FRC #1676
Team Role: Mascot
lil_longo has a spectacular aura aboutlil_longo has a spectacular aura aboutlil_longo has a spectacular aura about
Send a message via AIM to lil_longo
this software:
-Kevin
can you like dum that down for me cuz i want to learn programming and i didnt understand any of that i lost u after the first word
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
User input via serial port AJBelayer FIRST Tech Challenge 2 14-12-2005 18:54
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
