Go to Post Thanks, that clears things up a lot, and should probably have been obvious. - Branden Ghena [more]
Unread 27-01-2006, 17:32
winners winners is offline
winners is an unknown quantity at this point
Exclamation Camera Picture is Inverted
Hey,
I've got some problem, in all programs that "track" the green light, the tilt goes to the other side, like, instead of it going up, it goes down!
I recognized this from the tracking window in the LABView demo application by Mr. Diaz and when I try to capture a frame, either in LABView's demo application or the GUI CMUCam, the frame looks turned upside-down!
I'll appreciate any help!
Thanks.
Unread 27-01-2006, 19:56
Bharat Nain's Avatar
Re: Camera Picture is Inverted
Did you mount the camera upside down?????
There is a setting in Kevin Watsons camera code to change the direction the tilt and pan turns. Search in the forum and you will find many discussions about this.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 27-01-2006, 20:09
scottmso scottmso is offline
FRC #1561 (RoboDucks)
scottmso is an unknown quantity at this point
Send a message via AIM to scottmso
If your servos are connected to the CMUcam board, look in the pin diagram in your CMUcam manual and jumper the "tilt reverse" jumper on the board.
CMUCam2 GUI Tilt Question Idaman323 Programming 3 27-01-2006 02:01
CMUCam pan and tilt sheyna Programming 9 14-01-2006 23:20
Dashboard View of Pan and Tilt Servo Values JoeXIII'007 Programming 1 02-02-2005 22:34
Weight needed to tilt bridge... archiver 2001 4 23-06-2002 23:43
