Go to Post You enjoy your pepperoni pizza, I'll enjoy my cheese and peppers, and we can both agree that people that like pineapple on their pizza, while strange... are completely entitled to their opinions. - Andrew Schreiber [more]
Unread 18-01-2006, 20:17
eternalfire1244 eternalfire1244 is offline
Steve
FRC #1244 (Viking Robotics)
eternalfire1244 is an unknown quantity at this point
Send a message via MSN to eternalfire1244 Send a message via Yahoo to eternalfire1244
Re: Motors for ball launchers
"The spin axis parallel to the direction of flight helps maintain a straighter (more accurate) path because the projectile has ROTATIONAL INERTIA."
This is a valid argument, although in my personal experience the rotational inertia causes another type of inaccuracy- corkscrewing. This is especially true with barrels that are slightly bigger than the projectile, the ball bounces in the barrel and randomly bounces out of the muzzle. This action increases the "corkscrew effect".
Unread 18-01-2006, 20:25
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
You also have to think of the weight of the motor, if you are planing on using the super CIM for your cannon, presuming that your cannon is near the top of your robot, that is nearly 5 pounds at the top of your robot, for each one! Center of gravity! the only way to avoid this with the Super CIM is to use a few pounds of chain and sprockets. We are leaning toward the FP motors, with 'special' gearbox's.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 18-01-2006, 20:49
How about mounting the motor low and using a timing belt to drive your launcher?
Unread 27-01-2006, 23:07
zachriggle zachriggle is offline
FRC #1940
zachriggle is infamous around these parts
Our team is using the Drill motors attached to two Dryer rollers [think roller-blade wheels, but slightly larger, and made out of a much more grippy material] (we picked up two sets of the rollers that are used to keep Whirlpool and Kenmore dryers spinning). The end result is a VERY lightweight baseball-pitching mechanism that spins up in about 1.2 seconds (to maximum ball launching speed. Them suckers spin up for about 4 seconds if you let them get to it, but the balls exceed the maximum speed).
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
Suppose you want seat motors... archiver 2000 0 23-06-2002 22:50
