Go to Post Thinking (or the lack of it) will be our downfall. - sirbleedsalot [more]
Unread 27-01-2006, 23:13
zachriggle zachriggle is offline
FRC #1940
zachriggle is infamous around these parts
Between-Match Battery Swaps
I cant find anything against it in the rules, but I just want to check for legality:
1.) We CAN change batteries between matches, correct?
2.) We CAN have a total of more than two batteries to swap in/out, as long as only one is ever on the robot, correct?
In the event that both of the above are true, where might we be able to purchase more batteries? If most can get 2 matches out of a single battery with moderate power usage, you should be able to at least one match if you don't worry about battery consumption, correct?
Unread 27-01-2006, 23:21
ebmonon36's Avatar
ebmonon36 ebmonon36 is offline
AKA: Eric Bredehoeft
FRC #1018 (Robodevils)
ebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud of
Send a message via AIM to ebmonon36
Re: Between-Match Battery Swaps
Yes, you can change batteries out between matches and I would STRONGLY advise that you do this after every match just so your robot doesn't die.
As for the second part of your question:
5.3.5 Electrical System Rules
<R51> The only legal main source of electrical energy on the robot is the 12VDC non-spillable lead acid battery
provided in the Kit of Parts. That 12V battery is the Exide type EX18-12. The ES18-12 battery, purchased
through your local Exide supplier as a spare, is identical and may also be used. You may use other equivalent
type 12V batteries, but only during the Thursday practice rounds.
ERic
Unread 27-01-2006, 23:39
dubious elise's Avatar
dubious elise dubious elise is offline
Gone to school, back in 2016
FRC #0269 (Cooney Robotics); FLL #1855 (Cooney Tech/St. Jerome)
dubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond repute
1. Yes, you can change batteries between matches. I highly recommend doing this, it is far too risky to leave your battery in place for more than one match.
2. You can have as many competition-legal batteries to swap in/out as you desire. This is extremely important to take note of. The batteries take up to 6 hours to charge fully. Our team often brings a minimum of 10 batteries to each competition. At the Boilermaker Regional last year, I believe that we had 12 batteries in the morning and, by the final finals match, we were one of the few teams that still had batteries so we had to supply one battery, not only to ourselves, but also one to one of our alliance partners and one to an apposing alliance member. (we had an uncanny 4 matches in the finals)
As for where to purchase them, try a local NAPA Auto Parts store or Sam's Club - they are official retailers of Exide batteries, though stock may be spotty. I'd recommend checking online first for a better deal. Exide's website
also provides a tool for searching for local retailers.
"We can't guarantee success...but we can do something better, we can deserve it." ~John Adams
"The harder you work, the luckier you are." ~Gerald Ford
Notre Dame '10
Unread 27-01-2006, 23:41
Team Update 4 points to the Official Battery Order Form.
Unread 28-01-2006, 09:10
Please read carefully...some suppliers will try and sell you a cross referenced battery that is functionally the same but is not an EX or ES Exide battery. Accept no substitutes.
Unread 28-01-2006, 10:20
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
12 batteries is excessive if you ask me. With the 6A chargers FIRST provides these days, I don't really see a need for having more than 5 or 6 batteries, even if you have a crazy power-hungry robot. If you kill a battery every match, then you should rethink the mechanical design of your robot. If you plan it right, and you don't have a lot of back-to-back matches, and your robot doesn't draw a ton of power, you can certainly get through a regional with only 3 or 4.
My posts represent my personal views only, and do not represent the views of either my team, Team 190, nor its primary sponsor, Worcester Polytechnic Institute.
Unread 28-01-2006, 17:24
Originally Posted by BrianBSL
...If you plan it right, and you don't have a lot of back-to-back matches, and your robot doesn't draw a ton of power, you can certainly get through a regional with only 3 or 4.
However, if you plan to play in the finals, where closely-spaced matches tend to happen, you just might need that dozen or so batteries.
Unread 28-01-2006, 17:56
Ricky Q.'s Avatar Unsung FIRST Hero
Ricky Q. Ricky Q. is offline
yee haw!
FRC #0148 (Robowranglers)
Ricky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond repute
Send a message via AIM to Ricky Q.
Also, such as at Boilermaker last year, with the 3 on 3 format and smaller regionals you are playing matches closer together. Often times we would come back to the pits and already be called for our next match.
Ricky Quinones
Director of Sales - VEX Robotics
Unread 29-01-2006, 19:16
coldabert's Avatar
coldabert coldabert is offline
The Dude
FRC #0888 (Robotiators)
coldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of light
Send a message via AIM to coldabert
12 batteries is too many unless your robot drains an entire battery per 2 minute game.
Last year, our team could easily get 2 matches from a battery. However, in the final rounds, we used the freshest ones straight off the charger.
The most important advice I can give is to bring more than one charger and always have the batteries charging. Also, be sure to check the voltage of the batteries while their under a load, so that the high voltage from the charger wont confuse you.
Unread 01-02-2006, 15:30
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
we got by last year only using 2 batteries.
Unread 01-02-2006, 15:42
RoboMom RoboMom is offline
people expediter on Team Kluge
AKA: Jenny Beatty, no relation
no team (they are all my teams)
RoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond repute
The most important piece of advice I can give is have someone assigned to pay attention to the batteries. You cannot imagine how many teams end up saying "I thought you were charging the batteries..."
Co-Founder of NEMO (Non-Engineering Mentor Organization) www.firstnemo.org
Volunteer Director, STEMaction, Inc. www.stemaction.org
FIRST Senior Mentor: Nov. 2004 to June 2009: "Experience is that marvelous thing that enables you to recognize a mistake when you make it again"
This is How I Work: http://www.chiefdelphi.com/media/papers/2862
Unread 01-02-2006, 16:07
Wayne C.'s Avatar Unsung FIRST Hero
Wayne C. Wayne C. is offline
hey- I think we did pretty good?
FRC #0025 (Raider Robotix)
Wayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond repute
Our team carries a minimum of 8. They are numbered in a rotation according to their tested charge and pretested load capabilities. The pit setup also runs 4 chargers all the time. We have a pit crew person assigned to keeping track of the batteries and always haviing a freshly charged battery for each round. When we get the round schedule for the day we assign a battery number to each round and that way you never have a dead battery in a competitng robot.
The magic number of 8 serves two purposes. First- by the time you get to the 8th battery, the 1st one is well charged if you need it. Second- in the elimination rounds 8 batteries usually gets you through the three rotations. We have a little rolling cart with numbered slots for our batteries so we can take them to the field for the close-set elim matches.
Like our drivers/players, our batteries must compete for a number in the rotation. They do this by performing well in practice at home and holding the highest charges of the pool (currently 17) Generally they show their gratitude for being chosen by performing well.
Batteries do die after a few years, especially if you crash around a lot. It is always good to have a fresh set for the season..
Also- please dont forget the little auxilliary batteries. Without them you might have some problems with all the sensors this season. They also seem to charge rather slowly.
WC
you want that robot to do what?
Raider Robotix- www.raiderrobotix.org
Unread 01-02-2006, 17:03
Last year 330 made it through 5 rounds of eliminations at nationals with 5 batteries (4 of our own and 1 borrowed).
In 2004, 1405 made it through an entire regional + 3 rounds of eliminations with 2 batteries. We only had to charge each of them once.
Like BrianBSL said, it all depends on how you design.
Unread 05-02-2006, 22:00
pyrr101's Avatar
pyrr101 pyrr101 is offline
AKA: Travis
FRC #0537 (Charger Robotics)
Team Role: Electrical
pyrr101 is an unknown quantity at this point
Send a message via AIM to pyrr101 Send a message via MSN to pyrr101 Send a message via Yahoo to pyrr101
Our Team 537 last year with only 5 batteries and using the latest for the competitions and the older ones for practice worked out fine.
A tip for charging the batteries is to attach a set of connectors to the end of the charger like the ones that are on the leads for the battery for a good connection.
This can be done by clamping the clips to the end of an extra set of leads and electrical taping it for safety or find the connectors and replace the clips with it.
Good Luck this year!
Team 537 Electrical Lead
Waukesha County Sheriff Department, SWAT 'BOT lead
Wisconsin, Buckeye, and Nationals here we come!
Wisconsin Regional:
  • Rockwell Automation Innovation in Control Award
  • Regional Engineering Inspiration Award
  • Regional Winner
Unread 05-02-2006, 22:07
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Assign somebody to the specific task of managing the batteries. If they aren't on the robot, make sure they are on the charger. Change after every match. You should be okay with about 5 batteries.
Las Vegas Update SteveO Regional Competitions 31 09-04-2005 16:08
Actual SBPLI Finals Results/Video colt527 Regional Competitions 3 21-03-2005 20:52
Cryptology Ein Chit-Chat 17 14-03-2005 01:17
Sound Levels Measured at the Nationals archiver 1999 8 23-06-2002 22:47
Voltage Range of Analog Inputs Ulibrium Electrical 21 15-02-2002 14:11
