Go to Post We learned that no matter the outcome when you don't give up you will always win. - Koko Ed [more]
Unread 27-01-2006, 23:48
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: [Help] OI Modification
Originally Posted by zachriggle
Ooh, I like that idea a LOT more, actually. We'd need a hella bright LED array, though. Anyone know where to get a bunch cheap blue LED's (don't say Radioshack, because I said *cheap* LED's)?
The LED outputs on the OI are current-limited to 10 milliamps. This basically means you can connect only one LED to each output.
Speaking of LED's... is it legal to interfere with other teams' guidance systems (i.e. spewing lots of IR all over the field in order to mess with proximity sensors). I know it's not legal to cause physical damage, but the rulebook said nothing on this sort of defense.
You really should read through the whole manual... this question is also addressed directly:
<R31> No devices or decorations are permitted on the robot that are intended to jam or interfere with the operation of the vision system (i.e. changing robot color to confuse opponent’s vision system).
<R59> Custom Circuits may not:
• Interfere with the operation of other robots
Unread 28-01-2006, 08:24
zachriggle zachriggle is offline
FRC #1940
zachriggle is infamous around these parts
Is that in the Game section or Robot section (dont have a rulebook handy on me at the moment).
@Edit
Also, the "hella bright LED array" would not be on the OI, but rather on the robot itself (as had been suggested for a visual-cue for a lock-on, as opposed to a (however cool) lock-on tone).
Is there a milliamp limit on LED`s on the robot itself?
Dewalts modification suggestion Stephen Kowski Motors 1 05-07-2007 13:21
Globe motor modification Veselin Kolev Motors 11 26-01-2006 15:35
Joystick Modification Question wmurphy Control System 2 31-01-2005 00:29
Modification on the Torque motor? archiver 2001 0 23-06-2002 23:45
Caster Modification archiver 2001 1 23-06-2002 22:58
