Go to Post According to a recent study, 63% of teams admit they are behind. The other 37% are lying. - nitneylion452 [more]
Unread 28-01-2006, 08:45
clatek clatek is offline
serious business
AKA: ~kitty~
FRC #1761 (clatek)
Team Role: Student
clatek is an unknown quantity at this point
plexi glass
Can we use regular plexi glass?
"Keep it simple, stupid"
Unread 28-01-2006, 09:09
Jason Kixmiller's Avatar
Jason Kixmiller Jason Kixmiller is offline
IWIWAB
FRC #1747 (Harrison Boiler Robotics)
Jason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to behold
Send a message via AIM to Jason Kixmiller
Re: plexi glass
I would suggest not using plexi...it shatters with impact and is generally much harder to machine (depending on your application). If at all possible, try to use a product such as Lexan (very flexible and strong).
Lexan is a brandname...here is some information: http://www.gelexan.com/gelexan/features.html
there are other brands that offer the same features. Good luck!
Unread 28-01-2006, 09:29
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: plexi glass
The official name of PlexiGlas is acrylic. Try to avoid using acrylic on your robot at all costs; as up until a few years ago it was actually illegal to be used on a FRC robot. What you really want to use is called polycarbonate. The best known brand name of polycarbonate is Lexan. Polycarbonate it very strong, is used in some bullet-proof applications, and is nearly indestructible. Polycarbonate can be cut, drilled, heat-bent, machined, and much more. Spray paint takes well to polycarbonate, as long as you didn't paint the protective layer.
Polycarbonate also costs a lot more, which is why FIRST made acrylic legal to use. But in the long run, if you don't want to worry about having parts shatter, use polycarbonate.
Art Dutra IV
世上无难事,只怕有心人.
Unread 28-01-2006, 09:54
Leo 1529's Avatar
Leo 1529 Leo 1529 is offline
uber fabricata, webmasta, president
AKA: Tzu-san
FRC #1529 (Cyber-Cards)
Team Role: Webmaster
Leo 1529 has a spectacular aura aboutLeo 1529 has a spectacular aura aboutLeo 1529 has a spectacular aura about
Re: plexi glass
lexan is definately the way to go...we are covering our whole robot with it this year....its going to look like a see through refrigerator...
Unread 28-01-2006, 12:56
Re: plexi glass
What others have said -plexiglass is very difficult to work with. It melts around your saw blade, and if a drill bit snags the piece will shatter on you.
Lexan is just the opposite - it is SO nice to work with.
Unread 28-01-2006, 13:44
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Re: plexi glass
I have still seen polycarbonate shatter, but it was under extreme circumstances. Otherwise yes, polycarbonate is very good for robotics. It is almost like sheetmetal, you can shear it, bend it, punch it, heat it and curve it. This all comes at the price of polycarbonate being more expensive than acrylic.
Unread 28-01-2006, 16:02
Re: plexi glass
I few years back we wanted to test polycarbonate to see how rugged it was. We took a piece of 3/8" lexan, about 4" square and pounded a 1/2" diameter cold chisel through the center of it. We were able to chisel a hole completely through without cracking or breaking the piece.
I was very impressed! (so was the lexan :^)
Unread 28-01-2006, 20:45
Kirk Kirk is offline
FRC #0254
Kirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud of
Send a message via AIM to Kirk
Re: plexi glass
Check out this thread. http://www.chiefdelphi.com/forums/sh...ad.php?t=41571
Kirk
Unread 28-01-2006, 21:13
warcommander200's Avatar
warcommander200 warcommander200 is offline
FRC end-effecter group
AKA: David
FRC #0116 (Epsilon Delta)
Team Role: Student
warcommander200 will become famous soon enough
Send a message via MSN to warcommander200
Re: plexi glass
if you really want to go with a plexi glass like thing you should try to see if you can get some carbon fiber. it is as stong as steel and much liter but make sure before you cut it that not the type that you need a mask for because it becomes airborn. also it is very hard to get hold of. my team is using it this year to great afect.
ha ha ha,
Unread 29-01-2006, 10:19
Hutch Hutch is offline
NOTAG
Hutch will become famous soon enoughHutch will become famous soon enough
Re: plexi glass
Just in case there aren't enough reasons to NOT use plexiglass (acrylic) - when it's cut, it produces ammonia... not fun.
Unread 29-01-2006, 11:09
scitecteach's Avatar
scitecteach scitecteach is offline
AKA: Paula
#1446 (Robo-Knights)
scitecteach is an unknown quantity at this point
Send a message via AIM to scitecteach
Re: plexi glass
How do you order laxan?
Team 1446
NSBE born, NSBE bred and when I die I'll be NSBE dead!!!
Scitecteach
Unread 29-01-2006, 11:40
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Re: plexi glass
You can get it through a local plastic supplier, or several places online (including McMaster) sell it. You can just search for "lexan" on McMaster and it will translate that to polycarbonate for you.
My posts represent my personal views only, and do not represent the views of either my team, Team 190, nor its primary sponsor, Worcester Polytechnic Institute.
Unread 29-01-2006, 12:48
Dick Linn's Avatar
no team (Synergy)
Re: plexi glass
You might check this link to find a supplier in your area http://www.sheffieldplastics.com/distributor_form.cfm It's another brand of polycarbonate.
Check your local yellow pages. Loew's or Home Depot sometimes has the thinner stuff in the area where they have storm doors and windows, but you may get a better price from a plastics distributor.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 29-01-2006, 13:01
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
Re: plexi glass
With lexan all you need is 1/16" sheet for your robot, we are lucky to have GE Plastics sponsor us and the 1/16" stuff will save us a lot of weight. Oh and we can't break or shatter it, the most damage we could see is a little bending .
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Can we use Fiber Glass? waialua359 Technical Discussion 24 20-01-2006 13:48
Stuff Behind the glass SpaceOsc General Forum 19 03-03-2004 13:42
sensors edomus General Forum 5 19-11-2003 16:46
Plexi-Glass walls Brett W Rules/Strategy 8 21-02-2003 22:44
Special Glass Ian W. Chit-Chat 9 27-10-2002 00:37
