i am a newbie at the camera
OK, i am a complete newbie at the camera software and i have no idea what i am doing. i went through the LabVIEW tutorials and that didn't do much. I used the examples on another forum to see if i could understand what i am doing but that was very little help. http://www.chiefdelphi.com/forums/showthread.php?t=41214
i cant even get the camera to take a picture or show me what its looking at. after fiddling around with LabVIEW i see it as a very easy interface for basic programing. if any one could give me a step by step process to get LabVIEW to connect to the camera i will greatly appreciate it. |
Re: i am a newbie at the camera
Use Easy C instead.
First, are you getting power to the camera? Second, do you have both serial connections hooked up? (That's a no-no, by the way)
You have to get the guide from kevin.org or usfirst.org and follow it STEP-BY-STEP. Trust me, skimming over it without carefully reading and following the instructions to the letter will just leave you frustrated. |
To get a feel for the software......start by using last years cmucam2 software and play with that....its super easy to use and youll have an easier time problem solving....
try playing with http://www.cs.cmu.edu/~cmucam/cmucam2/CMUcam2GUI.zip labview is pretty advanced and somewhat hard to use.... good luck |
| How To Use the Google Camera | generalbrando | Kit & Additional Hardware | 2 | 07-02-2006 16:00 |
| Camera pointing error? | Craig Putnam | Programming | 14 | 21-01-2006 02:52 |
| Scripting Setup and the Camera + Serial Port Drivers | CJO | Programming | 22 | 11-01-2006 17:42 |
| Unresponsive camera | neilsonster | Programming | 9 | 17-02-2005 08:51 |
| CMUCam2 Camera Code - Are important parts commented out? | Mr. Lim | Programming | 4 | 14-01-2005 12:11 |
