Go to Post One button, ten copyrights, you do the math. - StephLee [more]
Unread 28-01-2006, 11:36
RedOctober RedOctober is offline
FRC #0291
RedOctober will become famous soon enoughRedOctober will become famous soon enough
More Digital I/O Help
Whats the difference between the rc_dig_inxx and the digital_io_xx variables? Thanks for any help.
Unread 28-01-2006, 17:32
Re: More Digital I/O Help
digital_io_01 is a control bit that determines whether the pin is an input or an output. rc_dig_in01 is the actual value read from the pin. See the first few lines of User_Initialization() in user_routines.c for an explanation of how to use them.
Digital I/O Help RedOctober Technical Discussion 2 27-01-2006 20:19
Digital Caliper as a Digital Readout on Small Mill sanddrag Technical Discussion 9 13-10-2005 22:51
Dynamic Input/Output Changing Paolo Control System 6 23-09-2004 19:09
digital i/o connectors Mercutio Electrical 4 19-01-2004 19:20
