Go to Post To my surprise, purple painted air tanks were illegal last year. AB - Andy Baker [more]
Unread 28-01-2006, 11:55
et1337's Avatar
et1337 et1337 is offline
et1337
AKA: Evan Todd
FRC #1317 (Digital Fusion)
et1337 is a glorious beacon of lightet1337 is a glorious beacon of lightet1337 is a glorious beacon of lightet1337 is a glorious beacon of lightet1337 is a glorious beacon of light
Thumbs down Gear Tooth Sensors
Before I even start... I've already searched all over the forums.
So, our interrupt software works, and we know our sensor is hooked up and oriented right, but the software didn't register any clicks. So we hooked up an oscilloscope to it, and it's not registering any sort of pulse. So... we need help. Is it broken, or what?
There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order.
et1337
Unread 28-01-2006, 13:01
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Re: Gear Tooth Sensors
Check that you're getting power, that it's the right voltage, and that it's clean. Check the datasheets to see the allowable voltage range, and make sure you're not using 5V when you should use 12, or vice versa.
One of the trickiest problems I've ever debugged electronically (I'm no expert, so this may be a 'duh' thing to anyone who knows what they're doing) was when my +5V power rail was too noisy - the multimeter registered 5 just fine, but when you hooked it up to a scope it actually oscillated between 5 and 0 at something ridiculous like 5MHz. That was playing strange games with my PIC's oscillator...
If you're sure you're getting good power, try a different one? Maybe it is broken.
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 28-01-2006, 17:42
Describe exactly how you have it hooked up. You say you know you did it right, but you'd probably say the same thing if you did it wrong.
Unread 28-01-2006, 19:56
Ryan M. Ryan M. is offline
Programming User
An excellent point. I'm on his team... and haven't the faintest idea how we have it hooked up.
To keep this post from being completely worthless, I know that at least one professional electrical engineer looked at it. Beyond that... *shrug*
Unread 28-01-2006, 21:09
DonRotolo's Avatar
Back to humble
FRC #0832
Thank you!
On the First hand, the hook up: From left to right, you want Ground, (nothing), +12 volts, Ground, +5 volts, and the last one is the signal output. That's right on the board.
On the Second hand: The GTS will sense the passing of a ferrous (Iron-based) object. Make sure a magnet will stick to your "gear".
On the Third hand: The Ferrous Gear must be within about 3 mm to be sensed. 1 mm is better and more reliable.
There is also a frequency limit, but it is doubtful you have reached that. Make sure the 'scope settings are such that you will see the pulses: The voltage will be around whatever is at the 5 volt input pin. You will see normally 0 volts with a brief pulse for each 'tooth'.
On our test rig, we used a flat steel bar, about 1/4" wide and 1/32" thick, 1.5 inches long, spun with one of the small fast motors in the KOP. We took great care to ensure the GTS was not struck by the bar as it spun.
Let us know how it turns out please! Also, we still can't figure out the interrupt code, so if you get something I'd be grateful if you could explain it to our programmer...
Don
Unread 28-01-2006, 21:36
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
try hooking it up away from the gear and just waving a ferous metal in front of it while it is hooked up to an oscilliscope to seeif you get a wave. If you do get a wave the sensor is not broken.
Unread 28-01-2006, 22:44
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Originally Posted by Don Rotolo
...Also, we still can't figure out the interrupt code, so if you get something I'd be grateful if you could explain it to our programmer...
There are a few documents in the white paper section. I know that Eugene Brooks and Dan Katanski have written papers, so you might search by author.
-Kevin
Edit: Here's a link to Dan Katanski's paper.
Kevin Watson
http://kevin.org
Unread 28-01-2006, 22:48
A "wave"? The GTS board produces a nice, clean, digital high-going pulse of less than a hundred microseconds each time it sees a gear tooth go by.
Will the gear tooth break? sanddrag Technical Discussion 11 23-01-2006 14:24
Source for Additional Gear Tooth Sensors Madison Kit & Additional Hardware 3 18-01-2006 16:57
Gear tooth sensor vs. Optical Encoders Avarik Programming 7 17-01-2006 10:18
Accelerometer vs Gear Tooth Sensors zdeswarte Electrical 4 22-01-2005 15:35
gears Michael Leicht Inventor 12 16-09-2004 10:52
