Go to Post you should be putting forth you best effort every time you enter the field. - Protronie [more]
Unread 28-01-2006, 13:24
pi_guy578 pi_guy578 is offline
Programmer/Electrician
AKA: Jake
FRC #0578 (Blue Lightning)
pi_guy578 has a spectacular aura aboutpi_guy578 has a spectacular aura about
Send a message via AIM to pi_guy578
Camera Library Problems
Ok I am having problems with camera code and I've narrowed it down to easyC. Check out this thread here. Hopefully I've made everything self explanitory in that thread. My easyC version is 2.5.0.1 if that helps. Feel free to ask any questions.
Jake
Unread 28-01-2006, 14:53
AKA: Jake
Re: Camera Library Problems
I've tapped the serial data and found the problem. In our increment code when it reaches 100 it instead sends then 11 ...19 until 110 when it actually sends 110. The same goes for 200: 20 21 ..29 until 210. You're missing a digit when sending the serial data, whenever the tens digit is a zero. Hope this helps.
Jake
Unread 29-01-2006, 09:13
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
We noticed this in testing this weekend and are working on a fix.
Problems Combining Camera Code and Driving Code cmurdoch Programming 20 10-02-2007 16:34
Camera Servo Problems pi_guy578 Programming 2 28-01-2006 13:17
problems mounting the camera to the 'bot with the default servo/mount set up Redneck Programming 0 16-02-2005 20:53
Camera Problems pickle Programming 21 20-01-2005 20:43
Camera "Grab Frame" Problems Isabel Cole Programming 7 15-01-2005 21:53
