Go to Post We try to limit ourselves only by physics. As the first person on the planet to communicate over a quantum encrypted AOL instant messenger session, I try to ignore those limits as well. - EricVanWyk [more]
Unread 28-01-2006, 13:58
Windward's Avatar
Windward Windward is offline
FRC #1452
Windward is an unknown quantity at this point
relay fwd & rev
What is the difference between the fwd and rev on the relays? I have heard that it can be used such that only one spike is needed to acuate a piston. How would we program so we could use one spike?
Unread 28-01-2006, 14:03
radicalnerd radicalnerd is offline
Registered Luser
FRC #0668 (Apes of Wrath)
radicalnerd is an unknown quantity at this point
Send a message via AIM to radicalnerd
Re: relay fwd & rev
I think what we did is hook up one side (red wire) of the solenoid to the M+ and the other to the M- then hook up both black wires to ground directly
hope it helps
Controlling Solenoids With Victors Brandon_Cmpvir Electrical 20 16-03-2004 10:21
Default mapping relay questions Jared Stofflett Programming 1 25-02-2004 19:06
Relay Aliases Backwards Jeff Zampieron Programming 19 18-02-2004 16:27
Drill Motor Output - Fwd vs Rev archiver 2000 1 23-06-2002 22:56
Relay Outputs OddOne Technical Discussion 3 01-02-2002 19:52
