Go to Post So, FIRST is turning into the For the Inspiration of Science and Trains? That makes sense... Not a whole lot of re-branding will be needed.... - dqmot17 [more]
Unread 28-01-2006, 11:22
itzrobz itzrobz is offline
None #0333
itzrobz is an unknown quantity at this point
Newbie Needs Help
hi, I am a newbie programmer. i have no idea how to setup the camera nor program. i've read the tilt/pan assembly, we built the camera but we don't know where anything else goes. like how to connect it to the computer, does it have to be connected to the RC to program it? where does it get its power from? and many more, we have read the manual and instructions but it still doesn't help.
please help us
Unread 28-01-2006, 11:54
Safarley2901's Avatar
Safarley2901 Safarley2901 is offline
AKA: Steve Farley
FRC #0808 (Mechanical Mayhem)
Safarley2901 has a spectacular aura aboutSafarley2901 has a spectacular aura aboutSafarley2901 has a spectacular aura about
Re: Newbie Needs Help
Originally Posted by itzrobz
Hi, I am a newbie programmer. I have no idea how to setup the camera nor program. I've read the tilt/pan assembly, we built the camera but we don't know where anything else goes. Like how to connect it to the computer, does it have to be connected to the RC to program it? Where does it get its power from? and many more, we have read the manual and instructions but it still doesn't help.
please help us
First off do you know C?
You want to connect a serial Cable, to the serial port on the camera, To a Serial port on your computer.
Using a PWM Cable you want to connect the power pins on the camera board, to a free PWM output on your Robot Controller. Make Sure that the Back Up Battery is plugged in.
Check this Camera Work book, its basically a tutorial.
http://www.kevin.org/frc/CMUcam2_workbook.pdf
This has an example code, that will give you a place to start.
Please Feel Free to ask what ever else you need. We'll help all we can.
Steven and Danny, Team 808.
Ps. We'll be here till about 9pm EST tonight so by all means repost
2005 Pittsburg Regional Finalists
2005 Cleveland Regional Semi finalists
Unread 28-01-2006, 16:30
None #0333
some of our members do,
anywasy we got it to work and track fo some time'
then it started moving away from the target.
now for some reason the camera is not comnucating with the computer. the red led don't want o blink anymore
any sugestions?
Unread 28-01-2006, 16:56
Kevin Watson's Avatar
La Cañada High School
FRC #2429
any sugestions?
Dead backup battery?
-Kevin
Kevin Watson
http://kevin.org
Unread 28-01-2006, 17:02
None #0333
the LEDs turn on, which means it has power, but we still cant connect to the camera. Does the camera require a backup battery as well as the main battery?
Unread 28-01-2006, 17:14
AKA: Steve Farley
The camera Runs off the back up battery. Once the back up battery is dead the camera stops working.
Steve Farley, Team 808
Unread 28-01-2006, 17:16
AKA: Steve Farley
Could have read my original reply. It says you need to attach a back up battery.
Unread 29-01-2006, 09:52
None #0333
~edit
it WORKS OMG OMG OMG. Thank you all so much
Unread 29-01-2006, 13:23
AKA: Steve Farley
~edit
No Problem Feel free to ask other questions if need be.
Team 808
Unread 30-01-2006, 10:22
None #0333
i have another problem i cant get Kevin's code to work ( bells and whistle.) i downloaded it to the rc but it doesnt seem to have any affect on the camera and the terminal window is blank. according to the CMUCam2 Workbook it should say "Searching..."
need help!!!!
thanks in advance
Unread 30-01-2006, 13:30
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
need help!!!!
thanks in advance
This may be a stupid question, but you did hook up the serial cable and TTL adapter between the camera and the RC, right?
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 30-01-2006, 18:35
None #0333
We hooked up the TTL adapter and a PWM cable between the camera and the RC, the servos into the PWM outputs, and the camera power into one of the PWM outputs. The thing we don't get is that where the serial cable is supposed to be hooked up to. We hooked it up connecting the COM port of our laptop and the Programming Port on the RC.
Unread 30-01-2006, 18:41
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Okay, coming off the camera itself, you will have two wires:
Power (goes to any free PWM port)
Serial (Goes to the small TTL board, which connects to the RC)
After that, each of the servo's connects to the correct port on the RC (pwm01 for pan, and pwm02 for tilt, IIRC)
Now, the "normal" (db9 (big black cable)) serial cable goes from the RC's program port to the laptop.
After doing all this, if it still doesn't work:
Charge your backup battery.
Use the dashboard to make sure the backup battery is charged.
Ensure all your PWM's are in the right places.
Check your backup battery (again!)
Lens cap off?
Camera focused? (Use labview)
Light have a good power supply (When the battery starts dieing, the camera can't find it as well)
Backup battery dead? (This is probably the most common problem we have had)
If all else fails, reload the default camera code (Which should track the target "out of the box")
Unread 30-01-2006, 18:59
None #0333
The default camera code is the Streamlined version of the camera right? We did everything correctly, according to you and the manual. I don't know whats wrong with it. We will try to download the streamlined version into the camera when we get a chance.
Just one question, Is the terminal window supposed to say "Searching..." even if the camera is not properly configured, with the focus, to search?
thanks for your help
Unread 30-01-2006, 20:41
Don't hook up both the DB9 cable to the computer and the "PWM" communication cable to the RC at the same time. They'll interfere with each other. Only use the computer if you're controlling the camera with the computer, and only use the cable to the RC if you're controlling the camera with the RC.
i am a newbie at the camera Capozzi Programming 3 28-01-2006 10:56
AHHH! I'm a lost newbie! I need help! lkdjm Programming 8 28-01-2006 08:41
quick question as a newbie Kristian Calhoun General Forum 8 26-10-2005 15:15
spur gears & fishers ...newbie question... archiver 2001 3 23-06-2002 23:17
Total newbie to the Chairman's Award A. Leese Chairman's Award 4 06-06-2001 22:03
