#17
Re: Kit Transmission
Some spring washers come in oversized and will cause this problem. Use the alternate assembly method using the setscrew with Loctite on the set screw and you will be fine.
| pic: Kit Transmission Upgrade kit | Andy Baker | Extra Discussion | 17 | 29-01-2006 01:27 |
| Tapping Into Kit Transmission Casing | Madison | Technical Discussion | 6 | 13-12-2005 14:29 |
| Kit Transmission Arm Config Update | Paul Copioli | Kit & Additional Hardware | 0 | 21-01-2005 15:07 |
| Kit of Parts - Sprocket Spacers? and Transmission Lubrication? | wmurphy | Kit & Additional Hardware | 10 | 13-01-2005 01:09 |
