Go to Post The first was a fish, all silver and spotted. “An opah?” I asked. “Yes,” my friend nodded. I knew not what it meant as I sat there and stared, But I appreciated the thoughts that the posters had shared. - Robotics692 [more]
Unread 12-01-2006, 10:44
President, VEX Robotics, Inc.
Re: Kit Transmission
I designed the gearbox with the spacer, because I do not like set set screws. The spacer, combined with the screw and washer at the end of the shaft, positively locates the gearbox in the correct spot. When I did prototyping last year, I used PVC tube for the spacer and it worked fine.
The manual, located at the IFI website, describes all of this in detail and provides a drawing for the spacer. I have attached my original drawing for the spacer in this E-mail.
-Paul
Unread 28-01-2006, 16:56
Courtney Courtney is offline
FRC #1735
Courtney will become famous soon enough
Send a message via AIM to Courtney
My team has found a problem with the kit transmissions. They followed the directions for the standard one-CIM configuration, but upon further testing, we realized that the spring washer was rubbing against one of the gears. Has anyone else had this problem? We are planning on removing the spring washer, and just putting loctite on the set screw.
Unread 28-01-2006, 17:10
Some spring washers come in oversized and will cause this problem. Use the alternate assembly method using the setscrew with Loctite on the set screw and you will be fine.
pic: Kit Transmission Upgrade kit Andy Baker Extra Discussion 17 29-01-2006 01:27
Tapping Into Kit Transmission Casing Madison Technical Discussion 6 13-12-2005 14:29
Kit Transmission Arm Config Update Paul Copioli Kit & Additional Hardware 0 21-01-2005 15:07
Kit of Parts - Sprocket Spacers? and Transmission Lubrication? wmurphy Kit & Additional Hardware 10 13-01-2005 01:09
