Go to Post We need to start building FIRST competition arenas and leasing them in the off-season to the sports teams and conventions ;) - protoserge [more]
  #46   Spotlight this post!
Unread 28-01-2006, 18:14
Capt.ArD Capt.ArD is offline
Animator
FRC #0116 (Epsilon Delta)
Team Role: Animator
Capt.ArD will become famous soon enoughCapt.ArD will become famous soon enough
Re: 3D Animation Q/A
Reactor isnt that hard you just need to sit down and learn it. the stuff it allows you to do is really sweet. I'll give anyone interested a rundown sometime if they want. Pm me about it.
  #47   Spotlight this post!
Unread 28-01-2006, 18:27
darkstar's Avatar
darkstar darkstar is offline
Animator
FRC #0585 (Warrior Robotics)
darkstar is an unknown quantity at this point
Send a message via Yahoo to darkstar
Anyone here?
  #48   Spotlight this post!
Unread 28-01-2006, 18:34
darkstar's Avatar
Animator
need help
  #49   Spotlight this post!
Unread 28-01-2006, 19:04
Damelvin's Avatar
Damelvin Damelvin is offline
Damelvin
AKA: J.D.
FRC #1147 (Herdinators)
Team Role: Animator
Damelvin is an unknown quantity at this point
Send a message via AIM to Damelvin Send a message via Yahoo to Damelvin
Which one is better cloth or reactor cloth, I heard anything using reactor can shutdown the program do to error. If i got time later I definetly would mind you showing me some tips about reactor.
Hear about the cannibal that passed his brother in the forest.
  #50   Spotlight this post!
Unread 28-01-2006, 19:24
Animator
Team Role: Animator
To be perfectly frank, i never learned cloth, only reactor cloth, so i don't know which is better.
Yes reactor can crash max, but only if you do no set up the reactor correctly. basically reactor is a physics engine like what some games have, only it is a lot more accurate. the accuracy therefore makes the program a lot more picky about how things are set up.
a good example is how objects interpolate. in a videogame, especially an older game, some objects can go through others. one example i remember is in Tomb raider you can lock Lara's butler in a freezer, and his hands and face stick through the door. If any object does that in reactor, it goes crazy for a while then crashes. it looks a lot like the objects exploded. so you always have to be careful not to have objects overlapping. other problems arise from all the vertices in an object being coplanar, low substeps (which will need to be explained better later on), or odd environment settings.
The overall product of a good reactor job is a very realistic and lifelike movement or arrangement. It's also really helpful for arranging things in a random manner. if you have a desk, papers are usually scattered all over, and pencils and things are lying all over. instead of taking the time to individually placing each object, you can just put them about 5 inches over the desk and let reactor make them fall down, landing in a random and realistic-looking mess. plenty of other uses, too. it's great fun.
wow long post
  #51   Spotlight this post!
Unread 28-01-2006, 19:38
Damelvin's Avatar
Damelvin
AKA: J.D.
Team Role: Animator
wow long post
Some help would be nice on the bed cover since I can't get the corners to look like i want them too.
  #52   Spotlight this post!
Unread 28-01-2006, 22:29
Damelvin's Avatar
Damelvin
AKA: J.D.
Team Role: Animator
Saw a guide online on how to make simple valance/curtain and I was wondeering if waht I did could pass as a curtain or should I mess with cloth.
  #53   Spotlight this post!
Unread 28-01-2006, 23:14
Damelvin's Avatar
Damelvin
AKA: J.D.
Team Role: Animator
Just wondering why are mov and mpeg the only video formats taht can be used as bitmaps? It gives me teh slection of avi but wont let me apply it.
  #54   Spotlight this post!
Unread 28-01-2006, 23:29
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
It should Ive used Avi before, It might be the compressor that the avi is using.
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
  #55   Spotlight this post!
Unread 29-01-2006, 14:26
Animator
Team Role: Animator
I know I have used Avi before as well. I don't know why you couldn't.
for the bed cover, if you want to reactor it i can help, but i don't have a lot of time right now. basically, look at the left side of the screen on max ant there is a button called "create rigid body collection" click and drop the icon anywhere in the scene, doesn't matter where. do the same thing for the cloth body collection. select the rigid one again and look at the modify panel. there is a little box where you can add objects from the scene to the collection. add your matress-thing object to that list. click the "cloth" object and apply the "reactor cloth" modifier to it. then add that object to the cloth body collection. you'll want to make sure you cloth has plenty of faces, 20x20 is pretty good. there, now the sene is set up, get ready to reactor it.
select the utilities tab at the top right of the screen (looks like a hammer) and slick on the reactor button in the list that apperas. open the first and last rollouts (should be animaiton and properties) next, select the cloth object, and in the properties rollout set the mass to about 1 or 2. this makes gravity affect the cloth. DO NOT give the mattress any mass. if you do the mattress will just fall out of the scene whene it calculates the the movement. while you have the cloth selected, look for where you define the boundary of the object and click the "define as proxy mesh" or something button. then select the cloth as the corresponding mesh.
my instructions are not clear, but you should be able to muddle it out. i'll be on CD or Gaim tommorrow night if you need better help.
when that is all set up, you can click on the "preview animation" in the animation rollout that you opened earlier. when you do, it will disaplay a list telling you if there are any errors in the scene. hopefully you will only see one that says that the object density is low. ignore it. then you will see a window with an untextured version of your scene. press "p" to initiate the simulation. your cloth shuld fall straight onto the matress, then drape itself around it. if it looks unrealistic, you can raise the substeps by using the menu at the top of that window. substeps ar the number of physics calculations per second, the more, the better. when you are pleased with the arrangement of the cloth, you can click the "update max" button at the top, and it will change your scene to cloth in its draped form.
like i said, this is a very superficial tut., but i can help more later on. my AIM is captainard2000. ill be on tommorrow night.
  #56   Spotlight this post!
Unread 29-01-2006, 22:07
darkstar's Avatar
Animator
Hi people, i need help with my tem's animation video. Does anyone know how to change from one background to another one in an animation video? If I don't reply you soon just pm me please
  #57   Spotlight this post!
Unread 29-01-2006, 23:24
Damelvin's Avatar
Damelvin
AKA: J.D.
Team Role: Animator
You mean like in the middle of a scene? Like you want to change one color from black to white during the animation. I would just turn on auto key and on material editor change the material or bitmap at the frame you want it to change. That should work. I have to do taht in my animation as part of a transition between scenes.
  #58   Spotlight this post!
Unread 30-01-2006, 00:55
darkstar's Avatar
Animator
Right, because at the start we have to have it black for part of the requirements, but I could not figure out how to change the image I want as the actually background in the animation, from the black one in the very begining.
  #59   Spotlight this post!
Unread 30-01-2006, 11:05
Animator
Team Role: Animator
Are you trying to make your animaton all in one go? If so, then yes, what damelvin said will work fine.
do you mean the 1 second of black at the beginning of the animation that is required? i wouldn't bother animating that, just use a movie editing program to add 1 second of black. most programs can do it.
BTW, is your signature image within size requirements? it takes up about half of my screen
  #60   Spotlight this post!
Unread 30-01-2006, 11:54
darkstar's Avatar
Animator
Actually it is five seconds with all that info. they want also. I'll try that material editor also though.
Animation Question Velaes 3D Animation and Competition 15 02-02-2005 00:11
FANATIC - Offseason Animation Competition opnickc 3D Animation and Competition 15 10-06-2004 20:54
A solution for Animation Judging for 2005 TKatsAniMentor 3D Animation and Competition 26 04-04-2004 15:29
A joke they called Regional Animation Competitions Lev 3D Animation and Competition 50 18-03-2003 21:18
How to develop your animation idea and keep your sanity too! Robby O 3D Animation and Competition 0 25-01-2002 01:25
