Go to Post It would be better as the software person to preach to your team early on for non-reliance on software. - Tom Bottiglieri [more]
Unread 28-01-2006, 21:53
Re: Serial Port Joysticks!!
Originally Posted by ghhs_1527
but all you would have to do is splice the ends to make it the other way
Um, no. Explaining why would take more time than I am willing to spend, but suffice it to say that USB just doesn't work that way. By design, a USB controller is a whole lot harder to make than a USB peripheral.
Unread 28-01-2006, 22:16
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
Originally Posted by gburlison
And they are not serial ports (9 or 25 pin connector or USB) they are joystick ports (15 pin connector). Might be time to build our own joystick. If FIRST Teams can build a robot, maybe we should be able to build a joystick. AndyMArk where are you?
The pin out for each port is listed in the OI reference guide. I modified our CH joysticks last year for external buttons, and will probably modify the newer sticks this year (you'd be surprised how stable these new joysticks become once you remove that huge hand grip). ArtDutra04 already mentioned Happ Controls, you can definately build your own joysticks with some of these very nice arcade style sticks.
Hmmm, maybe we'll do that this year!
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Unread 28-01-2006, 22:24
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
I was just thinking....
We (FIRST robotics teams) are capable of building complex 120+ lb robots, shouldn't we be able to build our own joysticks? How hard can it be?
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 28-01-2006, 23:06
How hard can it be?
Isn't this what is typically said by the garage tinkerer just before his invention explodes/melts down/malfunctions inscrutably/renders thousands of square miles uninhabitable?
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
User input via serial port AJBelayer FIRST Tech Challenge 2 14-12-2005 18:54
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
