Go to Post Gracious Professionalism does not take a holiday. - JaneYoung [more]
Unread 28-01-2006, 21:11
bush's Avatar
bush bush is offline
AKA: Aaron
FRC #0710 (Pine Crest School)
bush has a spectacular aura aboutbush has a spectacular aura about
Send a message via AIM to bush
Pre-programmed RGB values
I'm using Kevin's streamlined camera code. camera.h defines the default min/max RGB values that are used by Track_Color(). The mean RGB value is 100R, 16G, 122B (or #64107A in base 16). THIS IS THAT COLOR.. This obviously isn't green. I'm sure these are in fact the correct colors to use (I haven't tested yet), but I want to make sure I am understanding all of the code correctly.
I don't consider myself an expert on cameras, but my only guess would be that the color being programmed into the camera is the negative of the actual color we are tracking. Come to think of it, I think I remember learning somewhere that purple and green are complements.
In any event, somebody please explain
Unread 28-01-2006, 21:47
Re: Pre-programmed RGB values
Read the code a little more closely, with manual in hand to find out what the control registers mean, and you might find the spot where it puts the camera in YCrCb color mode. The values you see aren't RGB values. Does that help?
Unread 28-01-2006, 22:04
bush's Avatar
AKA: Aaron
Ah in State 9
I missed that before, thanks.
Unread 28-01-2006, 22:13
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Originally Posted by bush
Ah in State 9
It's also mentioned in the handy CMUcam2 FAQ: http://kevin.org/frc/camera.
-Kevin
Kevin Watson
http://kevin.org
Do you need the exposure values? Code\\Pilot Programming 5 20-02-2005 20:08
Paint values capenga Programming 1 20-02-2005 13:25
Acceleration Sensor Connected, but values are odd.... Leav Electrical 7 04-02-2005 15:28
trentonDrive.c: our joystick/wheel drive code gnormhurst Programming 16 03-02-2005 14:40
A testimony to my unique FIRST experience: Ken Leung General Forum 22 14-04-2004 20:45
