Go to Post the jocks may have muscle, but we have extruded aluminum :D - [527]phil [more]
Unread 28-01-2006, 10:41
MaddyW MaddyW is offline
FRC #0486
MaddyW is an unknown quantity at this point
Best place for PWM cables
Wheres the best(Cheapest) place to get PWM extension cables from?
Unread 28-01-2006, 11:11
SpaceOsc's Avatar
SpaceOsc SpaceOsc is offline
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
SpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant future
Send a message via AIM to SpaceOsc Send a message via Yahoo to SpaceOsc
Re: Best place for PWM cables
http://www.robotmarketplace.com/mark...onnectors.html
http://www.ifirobotics.com/accessories.shtml
look to spend from 4-6 bucks on each
Check local Hobbie stores, since pwms are used in most RC stuff
dont count out those Y cables they gave you too (Yellow, Red, Black) if you cut off one leg of it its and normal pwn cable, i personally i like using them to connect sensors that need pwms on them, cutting the big pwm cables (White, Red, Black) feels like a waste
2014-2017: Team 4501 Coach/Lead Mentor
2002-2011: Team 702, Mentor
2001-2002: Team 702 Captain
Unread 28-01-2006, 21:14
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
You can save some money and construct your own, and make your own custom lengths and custom sensor wiring as well.
All you need is some 3 pin molex connectors, some male and female pins,and maybe the pin insertion tool and crimping tool. Beyond that you just need some ribbon cable and your on your way to making PWN cables.
I know Digikey and alot of other places sell the tools/parts you need.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 28-01-2006, 23:31
Gary Bonner Gary Bonner is offline
FRC #3974
Gary Bonner has a spectacular aura aboutGary Bonner has a spectacular aura about
We made our onwn last year. All just the right length, no need to find a place to stash the extra cable, and five pin connectors for the encoders. We got ours from: http://hansenhobbies.com/products_connectorparts.html
Unread 29-01-2006, 17:26
DonRotolo's Avatar
Back to humble
FRC #0832
The one thing Digikey does NOT sell is the correct cable; you need 24 gauge wire (see R85) - best source I have found is eBay, search for HiTec Servo Wire, about $15 for 50 feet.
The 3 pin Molex connector bodies are on Digikey catalog page 110, as item WM2801-ND, but they are costly. I suggest buying the 7 pin bodies instead (WM2805-ND) and cutting them into two 3-pin pieces (sacrificing the center cavity).
Don't forget that you also need pins and sockets (like WM2512-ND and WM2515-ND), it would be a good idea to get a crimper (WM9999-ND) and perhaps an insertion tool (WM9911-ND).
Don
Unread 04-02-2006, 09:00
Dillon Compton Dillon Compton is offline
Jack-Of-All-Trades
FRC #1391 (Metal Moose)
Dillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud of
Send a message via AIM to Dillon Compton
Anyone know of a good source for male-to-female adaptors for PWM Cables?
www.metalmoose.com
Unread 11-10-2006, 23:10
DonRotolo's Avatar
Back to humble
FRC #0832
I recently found that All Electronics sells PWM extension and "Y" cables at reasonable prices. Go to their web site and search on Servo Extension. From their catalog:
CON404 4" $2.60
CON406 6" $2.75
CON412 12" $3.25
CON418 18" $3.65
CON424 24" $3.95
CON436 36" $4.50
CON412Y 12" Y $4.50
They also offer quantity discounts for 20 or more of any one item, about 10%
Have fun,
Don
Unread 12-10-2006, 00:28
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
We bought some cable, connectors and the economy crimping tool. I must say it is very time consuming to make your own cables, but now at least we have the ability to fix up the 20 or so broken old cables that are just sitting around. Our "Economy Crimping Tool" is pretty basic and you still have to "clean-up" the crimp with some needle nose pliers each time. Does anyone have experience with the "Deluxe Crimping Tool"?
Unread 12-10-2006, 00:37
CraigHickman
Posts: n/a
We got a bunch of CAT 5 plugs, so for this coming year we're going to use that to run 2 pwms across the bot. It'll save wiring management, space, and time. Plus, it makes it all a bit more modular. So you may want to consider this as an option.
Unread 12-10-2006, 01:02
AdamHeard's Avatar
Lead Mentor
I'm not sure the legality of this, but couldn't you take the 5v and signal from each PWM, and then have a common ground between three and hook that up to the breaker?
Also, doesn't that seem rather unnessacary? Most likely your controller and electrical panel should be near each other so it seems easier to just use PWMs rather than convert two PWMs to Cat5, then convert them back. It makes sense for something like the camera & servos, but overall it seems easier to just use PWMs.
Unread 12-10-2006, 01:03
yongkimleng yongkimleng is offline
deus ex programmeur
AKA: James Yong
FTC #0747
yongkimleng is a jewel in the roughyongkimleng is a jewel in the roughyongkimleng is a jewel in the rough
Send a message via MSN to yongkimleng
you mean cat 5 cables with rj45 heads? How do you manage the RJ45 sockets?
If +5v and GND can be shared, you can actually get 6 PWM signals across!
| jamesyong.net |
FVC2007, FTC2008
Unread 12-10-2006, 16:18
The Donger The Donger is offline
AKA: Nick Dong
FRC #0498
Team Role: Driver
The Donger is on a distinguished road
Just get servo wire, it's the exact same stuff.
http://www.servocity.com/html/servo_wire__bulk_.html
Unread 12-10-2006, 16:56
SuperJake's Avatar
SuperJake SuperJake is offline
No Problem!
AKA: Jake Classic
FRC #0061 (The Shifters)
SuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud of
Send a message via AIM to SuperJake
Thumbs up Re: Best place for PWM cables
Jameco is the best if you are looking to make your own servo wires. They are like the McMaster-Carr of hobby electronics - Digikey doesn't seem to have the hobby stuff. Enjoy.
http://www.jameco.com
Never send a person to do a robot's job.
Robots excel at Dull, Dirty, and Dangerous jobs.
Unread 14-10-2006, 23:37
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
We used to use the Molex connectors from Digikey, but last order I got the no-name Jameco ones. I prefer the Jameco ones as the pins are the correct length and not too long like the Molex ones. The Jameco pins/sockets are a bit more expensive (as the only option is gold plated) than the tin plated Molex pins/sockets, but the Jameco housings are cheaper.
We've always used 2 or 3-conductor 22ga Belden wire from Jameco (not twisted pair nor ribbon cable). A 100ft spool goes for $15 or so IIRC. There should be no noise issues as neither the 5V(Digital/analog)/7.2V(PWM) or GND have any AC component to them.
I suggest you do get the write crimper, as its less than $50 (and there's a cheaper one with fewer sizes for less than $20 IIRC), either way not too bad (compared to a $150 Anderson crimper). Crimping these with pliers won't create a reliable connection and soldering can cause issues with mechanical hard points.
My posts represent my personal views only, and do not represent the views of either my team, Team 190, nor its primary sponsor, Worcester Polytechnic Institute.
Bad Pwm cables Greg Needel Electrical 7 18-01-2006 23:13
PWM Extention Cables: 4 Shall Be the Limit Joe Johnson FIRST Tech Challenge 4 12-04-2005 23:33
The BRONX won 1st & 2nd place in NYC!! SouthBronx Thanks and/or Congrats 1 30-03-2003 22:33
Competition at UTC New England Rick Gibbs Regional Competitions 6 02-04-2002 09:25
